Testing with LN40B650 LCD TV
VeauX
Post Fri Apr 02, 2010 8:31 pm
HI,
Just to report my experience with serviio interacting with this TV. I used PC share manager since I bought the TV, my main usage is Movie streaming from my PC with the TV connected by wire to the router and the PC (on Win7) connected wirelessly to the router. My movies are on an external USB HDD connected to the PC
So far, MKV container with 1080P H.264 + AAC work good. Subtitles streaming also (.srt). My only issues was that I had to force Serviio to Samsung WiselinkPro under Render Profile to make it work. Leaving it to Auto detect wasn't working.
I'll follow on my tests. No FF/REW support over DLNA but this is a Samsung firmware issues (uberly annoying), btw does it work with another container/codec? just wondering.
So far I love that DNLA server. Congrats Zip! I was looking for a replacement of theur PC MEDIA SHARE for months!
Post Sun Apr 04, 2010 8:00 am
Re: Testing with LN40B650 LCD TV
Yeah, autodetect doesn't work for the Samsung (as stated on serviio.org), because the TV doesn't send enough information to identify itself.
FFWD worls with certain containers/codecs, but not MKV.
VeauX
Post Tue Apr 06, 2010 12:13 am
It seems someone did not do his homework good enough then! I missed that part.
Do you have a list of which container/coded do support REW/FF in order to do some testing?.
Post Tue Apr 06, 2010 10:54 pm
VeauX wrote:Do you have a list of which container/coded do support REW/FF in order to do some testing?.
No, would be useful if someone tried all different types of files and put it into a table.... maybe someone has done it before, not sure.
VeauX
Post Thu Apr 08, 2010 2:58 am
I have an issue. Or I think it's an issue.
When navigating the menus on the TV, sometime it becomes unresponsive. It happens more ofter when entering a folder. And even worse when I'm on the Series Menu and I open a full season of some serie.
What serviio does when I do this? does it rescan the whole folder? this might explain why.
Post Thu Apr 08, 2010 9:11 am
Could you turn on debug logging and post the bit when you try to open the series folder?
VeauX
Post Fri Apr 09, 2010 4:12 am
So, not sure this is the good portion but:
21:06:59,961 DEBUG [MediaItemDAOImpl] Getting file of media item 10280
21:06:59,961 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10281) and extractor EMBEDDED
21:06:59,962 DEBUG [MediaItemDAOImpl] Getting file of media item 10281
21:06:59,962 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10282) and extractor EMBEDDED
21:06:59,962 DEBUG [MediaItemDAOImpl] Getting file of media item 10282
21:06:59,963 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10283) and extractor EMBEDDED
21:06:59,963 DEBUG [MediaItemDAOImpl] Getting file of media item 10283
21:06:59,963 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10284) and extractor EMBEDDED
21:06:59,964 DEBUG [WebServer] Incoming connection from /192.168.1.107:2960
21:06:59,965 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
21:06:59,969 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R2, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 10, count = 1, sortCriteria =
21:06:59,970 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder null
21:06:59,971 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 2
21:06:59,972 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 1
21:06:59,973 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 4
21:06:59,974 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 5
21:06:59,974 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 7
21:06:59,975 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 8
21:06:59,976 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 510
21:06:59,976 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 520
21:06:59,977 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 10
21:06:59,977 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 14
21:06:59,978 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 16
21:06:59,978 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 18
21:06:59,979 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 20
21:06:59,979 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 22
21:06:59,980 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 23
21:06:59,980 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 27
21:06:59,981 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 28
21:06:59,982 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 9
21:06:59,983 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder null
21:06:59,985 DEBUG [MediaItemDAOImpl] Getting file of media item 10284
21:06:59,986 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10285) and extractor EMBEDDED
21:06:59,986 DEBUG [MediaItemDAOImpl] Getting file of media item 10285
21:06:59,987 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10286) and extractor EMBEDDED
21:06:59,987 DEBUG [MediaItemDAOImpl] Getting file of media item 10286
21:06:59,987 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10287) and extractor EMBEDDED
21:06:59,988 DEBUG [MediaItemDAOImpl] Getting file of media item 10287
21:06:59,988 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10288) and extractor EMBEDDED
21:06:59,988 DEBUG [MediaItemDAOImpl] Getting file of media item 10288
21:06:59,988 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
21:06:59,989 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10289) and extractor EMBEDDED
21:06:59,989 DEBUG [MediaItemDAOImpl] Getting file of media item 10289
21:06:59,990 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10290) and extractor EMBEDDED
21:06:59,990 DEBUG [MediaItemDAOImpl] Getting file of media item 10290
21:06:59,991 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10299) and extractor EMBEDDED
21:06:59,991 DEBUG [MediaItemDAOImpl] Getting file of media item 10299
21:06:59,992 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10300) and extractor EMBEDDED
21:06:59,992 DEBUG [MediaItemDAOImpl] Getting file of media item 10300
21:06:59,993 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10301) and extractor EMBEDDED
21:06:59,993 DEBUG [MediaItemDAOImpl] Getting file of media item 10301
21:06:59,994 DEBUG [LibraryUpdaterThread] Updating dirty metadata
21:06:59,994 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 2)
21:07:00,160 DEBUG [LibraryUpdaterThread] Updating dirty metadata
21:07:00,160 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 3)
21:07:00,165 DEBUG [LibraryUpdaterThread] Updating dirty metadata
21:07:00,165 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 4)
21:07:03,228 DEBUG [WebServer] Incoming connection from /192.168.1.107:2961
21:07:03,228 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
21:07:03,233 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R2, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 11, count = 1, sortCriteria =
21:07:03,233 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder null
21:07:03,235 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 2
21:07:03,236 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 1
21:07:03,237 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 4
21:07:03,237 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 5
21:07:03,237 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 7
21:07:03,238 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 8
21:07:03,238 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 510
21:07:03,238 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 520
21:07:03,239 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 10
21:07:03,239 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 14
21:07:03,240 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 16
21:07:03,240 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 18
21:07:03,240 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 20
21:07:03,241 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 22
21:07:03,241 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 23
21:07:03,242 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 27
21:07:03,242 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 28
21:07:03,243 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 9
21:07:03,243 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder null
21:07:03,248 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
21:07:04,256 DEBUG [WebServer] Incoming connection from /192.168.1.107:2962
21:07:04,257 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
21:07:04,261 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R2$F520, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
21:07:04,261 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder 520
21:07:04,280 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 520 (from=0, count=2147483647)
21:07:04,281 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
21:07:04,281 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 10303
21:07:04,869 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 10303
21:07:04,881 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 10303
21:07:04,894 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9141)
21:07:04,894 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 520
21:07:04,901 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
VeauX
Post Fri Apr 09, 2010 4:14 am
Also when I stop the playing of a file, it takes seconds before letting me choose something else.
And btw what the "**"mean after a folder name or a file name?
Post Fri Apr 09, 2010 8:23 am
From this log everything seems to be returned within a second.
The lag after you stop playing a file is caused by the same thing, it loads contents of the folder again.
The '*' marks last watched season/episode in the series category.
VeauX
Post Tue Apr 13, 2010 3:35 am
Ok I see, I've used more often the Server this week end. Pretty much only to see H264 MKV with AC3 with SRT subs. Everything's fine, I just encountered a couple of issues, not reproducible.
- once, one of the video stopped after 20 sec playing and it returned to the folder menue.
- and the other is that the server was not found by the TV and I had to manualy shut it down and restart via the console.
Besides this all good stuff.
The only cons I see vs PCMS is that navigation though folders using PCMS is almost instantaneous, no that much loading time besides the one when you start playing a file. Could something be done to Serviio to improve this? and btw, when will you have V4 out?
Post Tue Apr 13, 2010 8:48 am
Does it happen to the movie always or was it one off? The TV is quite sensitive to some formats, I guess a slight network lag might have caused it as well.
I'll try to speed up the navigation, that's my priority.
0.4 is still in development, hoping to have another beta out in a week.
VeauX
Post Wed Apr 14, 2010 12:57 am
If you need a beta tester, count me in! I will be pleased to test and give feedback.
zupamario
Post Sun Apr 25, 2010 1:37 am
I Just postet a feature request for seeking in mkv before reading this thread.
When serviio is done indexing I will post a list of video/audio/container for the files that I can get to work.
My TV is a ln32b650.
If I can help you out with anything else let me know.
Return to User experiences
