Status and Library do not work in the web-view
binkle
Post Fri Nov 15, 2019 10:30 pm
I just upgraded to the new version 2.0.
Now I'm no longer able to use the menus "Status" and submenus of "Library".
Each time I select one of them I get a messagebox telling "Cannot connect to Serviio server, it does not seem to be running."
All other menu items seem to work.
Additionally I'm not able to find any option about the new users feature.
Any suggestions to these problems?
Post Sat Nov 16, 2019 2:04 am
Re: Status and Library do not work in the web-view
This sounds like it might be a browser cache issue. Try deleting your browser cache and try again. Or, you could try a different browser on the same computer, or a different computer that didn't access the old version of the console. Especially since you can't find the new Users option, it's kind of a giveaway.
binkle
Post Sat Nov 16, 2019 7:00 pm
no it definitelly was browser issue, the a inkognito tab showed it too.
But now after one day it's gone.
Now I can also see the user menu item.
Thanks!
Greetings
Harry
Users browsing this forum: No registered users and 59 guests
