Identify the right device on the Status tab
Tarkin
Post Tue Apr 05, 2011 2:51 pm
With Blue ray player, TV, netbook, iPad, Android Phone and home PC all connected to my home network, how do I know which one is which on the Status tab which lists devices that were found on my network?
I am asking this because I want to set each device the right profile and I am not sure how to identify the right device.
Also, how do I get rid of the Windows Media Players servers (from my home PC) which keep on cropping up (to my annoyance :? ) on the Serviio console?
Post Tue Apr 05, 2011 3:05 pm
Re: Identify the right device on the Status tab
You should check on your router on on the Device itself for the IP address. Ideally you should set up static IP for all your connected devices on the router so that they don't change over time.
You cannot, it's a valid DLNA renderer device and therefore will be added to the list every time it's available on the network.
Post Tue Apr 05, 2011 3:10 pm
you can if you completely disable the DLNA functions from windows services :)
Post Tue Apr 05, 2011 4:02 pm
ah cool, I guess I should do it on my box too :-)
Post Tue Apr 05, 2011 4:16 pm
zip wrote:ah cool, I guess I should do it on my box too :-)
seemed to speed my network up too
Tarkin
Post Tue Apr 05, 2011 7:32 pm
zip,
'You should check on your router on on the Device itself for the IP address. Ideally you should set up static IP for all your connected devices on the router so that they don't change over time.'
>>I would love to set up static IP for all my connected devices...Can you tell me how or point out a guide on the web?
Thanks!
Post Tue Apr 05, 2011 8:04 pm
Tarkin wrote:zip,
Thanks!
not without knowing the make and model of your router ;)
Tarkin
Post Tue Apr 05, 2011 8:15 pm
Cerberus wrote:
Tarkin wrote:zip,
Thanks!
Netgear WPN824
Post Tue Apr 05, 2011 8:30 pm
Tarkin wrote:
Cerberus wrote:
Tarkin wrote:zip,
Thanks!
Netgear WPN824
EDIT: opps wrong link here one i ment to post http://www.google.co.uk/url?sa=t&source ... Pas8kIkHAg
Tarkin
Post Tue Apr 05, 2011 10:03 pm
It works! Good riddance! Thanks mate.
Tarkin
Post Tue Apr 05, 2011 10:11 pm
Thanks...Hmmm...I am not sure this is telling me how to set up static IP for all my connected devices or am I missing something? Is getting inside the router and making the changes easy to do?
Post Wed Apr 06, 2011 9:51 am
Tarkin wrote:EDIT: opps wrong link here one i ment to post http://www.google.co.uk/url?sa=t&source ... Pas8kIkHAg
that is the manual for you router. just read it :) and you cant setup static ips without going into the router :)
Users browsing this forum: No registered users and 57 guests
