Content not refreshing
wounder if updating the FFMPEG file might help? -> https://wiki.serviio.org/doku.php?id=win_ffmpeg
atc98092 wrote:ffmpeg is only used (to my knowledge) for transcoding. I don't think it's invoked for folder monitoring. Sometimes it can help if you enable the poller function on your library folders. On the Serviio console go to the Shared Folders tab, then click Edit on your configured shared folders. One of the options is to enable polling the folder for updates. Save the changes and you're done. It doesn't require restarting the server to take effect.
Users browsing this forum: Google [Bot] and 43 guests
