Serviio 2.0 can't be stopped and started
Jack Hidley
Post Fri Dec 13, 2019 9:08 pm
Win 7 64 bit machine with SP1.
Previously had Serviio 1.4 installed, I believe.
Updated to Serviio 2.0. Now I can not stop or start the service. I have tried doing this directly from the command prompt and from Services control panel.
At the command line when I enter "serviioservice -start" I get "Could not start service. Error code: 5" Doing a quick Google search, this seems to be related to some type of directory permissions.
When Serviio is running, if I try to stop the service, I think I get "Could not stop service."
In the Services control panel, Serviio is setup to start automatically.
Any ideas what is going on here?
Jack Hidley
Post Fri Dec 13, 2019 10:31 pm
Re: Serviio 2.0 can't be stopped and started
So I uninstalled 2.0 and reinstalled it. No change.
Then I uninstalled 2.0 and reinstalled 1.10. No change.
At the command prompt if I try to start or stop Serviio I get the same errors as below.
If I use the Services control panel to start Serviio, it shows that it is started for about 5 seconds, then it changes to stopped. It shows exactly the same thing in Task Manager.
I've rebooted the computer multiple times and tried selecting Automatically ( with delayed start). No change in behavior.
Post Sat Dec 14, 2019 2:20 am
Your Serviio log should indicate what is causing the service to stop. We need to see the log to determine what's going on. Sounds like some other application is interfering with Serviio.
Jack Hidley
Post Sat Dec 14, 2019 2:51 am
Dan,
I was trying to turn on debugging in the xml file when this started. I have done that, but since then I can't get Serviio to start, thus no log.
Jack Hidley
Post Sat Dec 14, 2019 3:19 am
I take it back. Actually it appears that Serviio has been attempting to actually start, because it has added a lot of comments to the log file. Below is the last segment of it.
2019-12-13 14:25:22,708 WARN [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2019-12-13 14:25:22,708 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2019-12-13 14:25:22,708 WARN [IndexedDiskCache] Region [subtitles_metadata] Disk cache not shutdown properly, shutting down now.
2019-12-13 14:25:22,708 WARN [IndexedDiskCache] Region [subtitles] Disk cache not shutdown properly, shutting down now.
2019-12-13 14:25:22,708 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2019-12-13 14:25:26,737 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2019-12-13 14:25:26,737 INFO [MediaServer] ------------------------------------------------------------------------
2019-12-13 14:25:26,737 INFO [MediaServer] Serviio DLNA media streaming server v 1.10.1 (rev. 3e5b0ba57122)
2019-12-13 14:25:26,737 INFO [MediaServer] Petr Nejedly 2009-2018
2019-12-13 14:25:26,737 INFO [MediaServer] http://www.serviio.org
2019-12-13 14:25:26,737 INFO [MediaServer] Java 1.8.0_191-Oracle Corporation x86
2019-12-13 14:25:26,737 INFO [MediaServer] OS Windows 7 6.1
2019-12-13 14:25:26,737 INFO [MediaServer] File encoding: windows-1252
2019-12-13 14:25:26,784 INFO [MediaServer] Headless mode enabled: true
2019-12-13 14:25:26,784 INFO [MediaServer] User: SPEED-II$
2019-12-13 14:25:26,784 INFO [MediaServer] User home dir: C:\Windows\system32\config\systemprofile
2019-12-13 14:25:26,784 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2019-12-13 14:25:26,784 INFO [MediaServer] ------------------------------------------------------------------------
2019-12-13 14:25:26,784 DEBUG [MediaServer] Runtime params: -Dexe4j.semaphoreName=Local\c:_program_files_pc5dczc_bin_serviioservice.exe0, -Dexe4j.isService=true, -Dexe4j.moduleName=C:\Program Files\Serviio\bin\ServiioService.exe, -Dexe4j.tempDir=C:\Windows\TEMP\e4j5F2F.tmp_dir1576275926, -Dexe4j.unextractedPosition=413627, -Djava.library.path=C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Microsoft Windows Performance Toolkit\;;c:\program files\serviio\jre\bin, -Dexe4j.consoleCodepage=cp0, -Xms20M, -XX:+UseG1GC, -XX:GCTimeRatio=1, -XX:MinHeapFreeRatio=10, -XX:MaxHeapFreeRatio=20, -Djava.net.preferIPv4Stack=true, -Djava.awt.headless=true, -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade, -Dserviio.home=C:\Program Files\Serviio\bin\\.., -Dderby.system.home=C:\Program Files\Serviio\bin\\..\library, -Xmx512m, -Xrs
2019-12-13 14:25:26,799 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2019-12-13 14:25:26,815 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2019-12-13 14:25:26,815 INFO [DatabaseManager] Using DERBY database language
2019-12-13 14:25:28,330 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2019-12-13 14:25:28,330 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2019-12-13 14:25:28,330 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2019-12-13 14:25:28,330 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2019-12-13 14:25:28,330 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2019-12-13 14:25:28,330 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2019-12-13 14:25:28,330 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-1.5.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-1.6.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-1.7.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-1.8.sql' has been run
2019-12-13 14:25:28,346 DEBUG [DBLogDAOImpl] Checking if script 'script-1.9.sql' has been run
2019-12-13 14:25:28,424 INFO [WebServer] Socket buffer set to 65535 bytes
2019-12-13 14:25:28,424 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2019-12-13 14:25:28,424 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2019-12-13 14:25:28,424 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2019-12-13 14:25:28,424 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2019-12-13 14:25:29,001 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/cds) exposed on port 23424
2019-12-13 14:25:29,001 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/mediabrowser) exposed on port 23424
2019-12-13 14:25:29,001 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/cds) exposed on port 23524
2019-12-13 14:25:29,001 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/mediabrowser) exposed on port 23524
2019-12-13 14:25:29,032 DEBUG [LicensingManager] Updating license
2019-12-13 14:25:29,032 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2019-12-13 14:25:29,048 DEBUG [LicenseValidator] Validating license file (351 bytes)
2019-12-13 14:25:29,250 INFO [MediaServer] ------------------------------------------------------------------------
2019-12-13 14:25:29,250 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2019-12-13 14:25:29,250 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2019-12-13 14:25:30,030 INFO [Device] Created UPnP Device with UUID: dbe6fccc-5bf2-3883-9929-daf5b210e7ed, bound address: 192.168.1.105
2019-12-13 14:25:30,093 INFO [ProfileManager] Loading profiles from file /profiles.xml
2019-12-13 14:25:30,280 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2019-12-13 14:25:30,280 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2019-12-13 14:25:30,296 INFO [CustomisationManager] No customisation properties found
2019-12-13 14:25:30,342 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2019-12-13 14:25:30,342 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2019-12-13 14:25:30,358 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2019-12-13 14:25:30,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2019-12-13 14:25:30,358 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2019-12-13 14:25:30,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2019-12-13 14:25:30,358 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2019-12-13 14:25:30,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ps4
2019-12-13 14:25:30,358 INFO [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2019-12-13 14:25:30,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2019-12-13 14:25:30,358 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2019-12-13 14:25:30,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2019-12-13 14:25:30,358 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2019-12-13 14:25:30,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_h
2019-12-13 14:25:30,358 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2019-12-13 14:25:30,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_j
2019-12-13 14:25:30,358 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2019-12-13 14:25:30,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_m
2019-12-13 14:25:30,358 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (M-series)' (id=sam_m)
2019-12-13 14:25:30,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_ef
2019-12-13 14:25:30,358 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2019-12-13 14:25:30,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2019-12-13 14:25:30,358 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2019-12-13 14:25:30,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2019-12-13 14:25:30,358 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2013
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2013
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile tosh2012
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2013
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2009
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2009)' (id=viera2009)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile panasonicBDT220
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile philips_streamium
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile roku
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuMPApp
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Roku4kMPApp
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Roku 4K Media Player (2016+)' (id=Roku4kMPApp)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuNo4kApp
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Roku 1080 Media Player (2016+)' (id=RokuNo4kApp)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuTV
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Roku TV (non 4K)' (id=RokuTV)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Roku4kTV
2019-12-13 14:25:30,374 INFO [ProfilesDefinitionParser] Added profile 'Roku 4K TV' (id=Roku4kTV)
2019-12-13 14:25:30,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Roku4kMPM2
2019-12-13 14:25:30,389 INFO [ProfilesDefinitionParser] Added profile 'Roku 4K Media Player w/MPEG2' (id=Roku4kMPM2)
2019-12-13 14:25:30,389 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile YamBD
2019-12-13 14:25:30,389 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2019-12-13 14:25:30,389 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile TNDC
2019-12-13 14:25:30,389 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2019-12-13 14:25:30,389 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbox_one_s_x
2019-12-13 14:25:30,389 INFO [ProfilesDefinitionParser] Added profile 'Xbox One S/Xbox One X' (id=xbox_one_s_x)
2019-12-13 14:25:30,389 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2019-12-13 14:25:30,389 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile raumfeld
2019-12-13 14:25:30,389 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2019-12-13 14:25:30,389 INFO [ProfileManager] Loading profiles from file /application-profiles.xml
2019-12-13 14:25:30,405 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2019-12-13 14:25:30,405 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2019-12-13 14:25:30,405 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2019-12-13 14:25:30,405 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile html5
2019-12-13 14:25:30,405 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2019-12-13 14:25:30,405 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile html5_mobile
2019-12-13 14:25:30,405 INFO [ProfilesDefinitionParser] Added profile 'HTML5 Mobile' (id=html5_mobile)
2019-12-13 14:25:30,405 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_standard
2019-12-13 14:25:30,405 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2019-12-13 14:25:30,405 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2019-12-13 14:25:30,405 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_hls
2019-12-13 14:25:30,405 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2019-12-13 14:25:30,405 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_gtv
2019-12-13 14:25:30,405 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2019-12-13 14:25:30,405 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile googlecast
2019-12-13 14:25:30,405 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2019-12-13 14:25:30,405 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile chromecast
2019-12-13 14:25:30,405 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2019-12-13 14:25:30,405 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile alexa
2019-12-13 14:25:30,405 INFO [ProfilesDefinitionParser] Added profile 'Alexa' (id=alexa)
2019-12-13 14:25:30,405 INFO [ProfileManager] Loading profiles from file /user-profiles.xml
2019-12-13 14:25:30,420 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-complex-type.2.4.a: Invalid content was found starting with element 'Audio'. One of '{ProtocolInfo, DeviceDescription, ResourceTransportProtocolHandler, ContentDirectoryDefinitionFilter, H264LevelCheck, OnlineTranscoding, GenericTranscoding, AlternativeQualities, AutomaticImageRotation, AllowedImageResolutions, LimitImageResolution, Subtitles, ThumbnailsResolution, AllowChunkedTransfer, MultipleAudioTrackAware}' is expected.
2019-12-13 14:25:30,420 ERROR [MediaServer] An unexpected error occurred. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
at org.serviio.profile.ProfileManager.parseProfilesFromFile(ProfileManager.java:186)
at org.serviio.profile.ProfileManager.loadProfiles(ProfileManager.java:160)
at org.serviio.MediaServer.main(MediaServer.java:136)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:62)
at com.exe4j.runtime.WinLauncher$2.run(WinLauncher.java:96)
Caused by: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
at org.serviio.profile.ProfilesDefinitionParser.validateXML(ProfilesDefinitionParser.java:1054)
at org.serviio.profile.ProfilesDefinitionParser.parseDefinition(ProfilesDefinitionParser.java:154)
at org.serviio.profile.ProfileManager.parseProfilesFromFile(ProfileManager.java:184)
... 8 more
2019-12-13 14:25:30,420 WARN [IndexedDiskCache] Region [subtitles] Disk cache not shutdown properly, shutting down now.
2019-12-13 14:25:30,420 WARN [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2019-12-13 14:25:30,420 WARN [IndexedDiskCache] Region [subtitles_metadata] Disk cache not shutdown properly, shutting down now.
2019-12-13 14:25:30,420 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2019-12-13 14:25:30,436 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
I was trying to setup a user-profiles.xml file. I'll yank that from the directory and see if it fixes the problem.
I tried that and now I can start Serviio, but only by using Services control panel. Below is part of the new log file from the very end.
2019-12-13 19:05:03,461 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-12-13 19:05:03,461 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.103
2019-12-13 19:05:03,661 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-12-13 19:05:03,681 DEBUG [ServiioHttpService] Incoming request from /192.168.1.103:40547: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.105:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 273,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"]]
2019-12-13 19:05:03,681 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-12-13 19:05:03,681 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.103
2019-12-13 19:05:03,891 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV (2012)'
2019-12-13 19:05:03,901 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-12-13 19:05:04,001 DEBUG [ServiioHttpService] Incoming request from /192.168.1.103:40548: GET /deviceDescription/dbe6fccc-5bf2-3883-9929-daf5b210e7ed HTTP/1.1, headers = [Host: 192.168.1.105:8895,Date: Sat, 14 Dec 2019 03:05:04 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";]]
2019-12-13 19:05:04,001 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-12-13 19:05:04,001 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device dbe6fccc-5bf2-3883-9929-daf5b210e7ed from 192.168.1.103 (headers = [Host: 192.168.1.105:8895,Date: Sat, 14 Dec 2019 03:05:04 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";])
2019-12-13 19:05:04,001 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.105:8895,Date: Sat, 14 Dec 2019 03:05:04 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";]
2019-12-13 19:05:04,011 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV (2012)'
2019-12-13 19:05:04,031 DEBUG [ServiioHttpService] Incoming request from /192.168.1.103:40549: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.1.105:8895,Date: Sat, 14 Dec 2019 03:05:04 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";]]
2019-12-13 19:05:04,031 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-12-13 19:05:04,031 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2019-12-13 19:05:04,031 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-12-13 19:05:04,061 DEBUG [ServiioHttpService] Incoming request from /192.168.1.103:40550: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.1.105:8895,Date: Sat, 14 Dec 2019 03:05:04 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";]]
2019-12-13 19:05:04,061 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-12-13 19:05:04,061 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2019-12-13 19:05:04,061 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-12-13 19:05:04,091 DEBUG [ServiioHttpService] Incoming request from /192.168.1.103:40551: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.105:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 280,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"]]
2019-12-13 19:05:04,101 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-12-13 19:05:04,101 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.103
2019-12-13 19:05:04,311 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-12-13 19:05:04,351 DEBUG [ServiioHttpService] Incoming request from /192.168.1.103:40552: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.105:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 273,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"]]
2019-12-13 19:05:04,351 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-12-13 19:05:04,351 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.103
2019-12-13 19:05:04,361 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-12-13 19:05:04,491 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:40 (advertisement duration is 1800 sec.)
2019-12-13 19:05:04,571 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV (2012)'
2019-12-13 19:05:04,581 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
Serviio has spent over 5 minutes (it was started at 19:00:00) communicating with devices on the network. I suspect that it is ignoring the command to stop from windows. Is this possible?
I just checked the log again. It is stil ltrying to communicate after 9 minutes.
I opened Serviio control panel. It has slightly incorrectly identified my TV. I changed it to the correct TV type and clicked Save. Now I go back to the log file and it can communicate with the TV and appears to have stopped adding lines to the log file. Below are the last few.
2019-12-13 19:14:49,979 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.105
2019-12-13 19:14:49,979 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.105:59436s
2019-12-13 19:14:50,038 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2019-12-13 19:14:50,049 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2019-12-13 19:14:50,149 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.103:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-12-13 19:14:50,149 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-9034fcda963d from address 192.168.1.103
2019-12-13 19:14:50,150 DEBUG [RendererManager] Retrieve device description from http://192.168.1.103:52323/dmr.xml
2019-12-13 19:14:50,345 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.103:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-12-13 19:14:50,345 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-9034fcda963d from address 192.168.1.103
2019-12-13 19:14:50,345 DEBUG [RendererManager] Retrieve device description from http://192.168.1.103:52323/dmr.xml
2019-12-13 19:14:51,586 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.103:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-12-13 19:14:51,587 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-9034fcda963d from address 192.168.1.103
2019-12-13 19:14:51,587 DEBUG [RendererManager] Retrieve device description from http://192.168.1.103:52323/dmr.xml
2019-12-13 19:14:55,978 DEBUG [RendererSearchSender] Finished searching for Renderer devices
I still can't stop Serviio from either the command line or the self installed options in the start menu.
Jack Hidley
Post Sat Dec 14, 2019 3:46 am
Now I've reinstalled Serviio 2.0. I can stop and start it, but I must do both of these through the Services control panel.
The log file looks normal.
Next problem. I made up my own user-profiles.xml file so that I could modify the xml for two of my devices. The TV and a new Blue Ray player. Each device can receive LPCM audio. All of my audio is stored in WMA lossless. For years I've just inserted the xml code below into the profile for my TV and it worked fine. The problem of course is that when you update Serviio, you lose all of your custom changes.
Here is the section of code that I inserted in the user-profiles.xml file:
<Audio targetContainer="lpcm" forceInheritance="true">
<!-- To allow "pause" then "resume" functions and album art for TVs that support it - transcode to mp3 instead -->
<Matches container="asf" />
<Matches container="ogg" />
<Matches container="flac" />
</Audio>
Here is the entire xml file, that is causing Serviio to not start. Any idea what is wrong with it?
<Profiles version="1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="http://www.serviio.org/xsd/profiles/v/2.0/Profiles.xsd">
<Profile id="sony2012us" name="Sony Bravia TV (2012) - US Jack" extendsProfileId="sony2012">
<!-- 2012 models for US (without avi/divx)
- Still images: JPEG, MPO
- Music: MP3, linear PCM, WMA, MP4
- Video: AVCHD, MPEG2, MPEG1, MP4 (AVC), MP4 (MPEG4), WMV -->
<!-- Transcode DivX, AVI -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" forceInheritance="true">
<Matches container="avi" vCodec="mpeg4" />
<Matches container="avi" vCodec="msmpeg4" />
</Audio>
<Profile id="panasonicBDT220" name="Panasonic BD player Jack" extendsProfileId="1">
<Detection>
<UPnPSearch>
<FriendlyName>DMP-BDT220/221</FriendlyName>
<Manufacturer>Panasonic</Manufacturer>
</UPnPSearch>
</Detection>
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
</MediaFormatProfiles>
<Video targetContainer="mpegts" maxVBitrate="15360" DAR="16:9">
<Matches container="*" vCodec="mpeg2video" aCodec="ac3" />
<Matches container="matroska" vCodec="h264" aCodec="ac3" />
<Matches container="*" vCodec="mpeg2video" aCodec="eac3" />
<Matches container="matroska" vCodec="h264" aCodec="eac3" />
<Video targetContainer="mpegts" targetACodec="ac3" maxVBitrate="15360" DAR="16:9">
<Matches container="*" vCodec="mpeg2video" />
<Matches container="*" vCodec="h264" aCodec="dca"/>
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="15360" DAR="16:9">
<Matches container="*" vCodec="h263" />
<Matches container="mp4" vCodec="mpeg4" />
<Matches container="mp4" vCodec="msmpeg4" />
<Matches container="mpegvideo" />
<Matches container="mpeg" />
<Matches container="mpegts" />
<Matches container="avi" />
<Matches container="flv" />
<Matches container="wtv" />
<Matches container="3gp" />
<Matches container="rtp" />
<Matches container="rtsp" />
<Matches container="rm" />
<AudioTrackRemux>
<Matches container="*" vCodec="h264" />
<Matches container="*" vCodec="mpeg1video" />
<Matches container="*" vCodec="mpeg4" />
<Matches container="*" vCodec="msmpeg4" />
</AudioTrackRemux>
</Audio>
</Profiles>
FYI, the Blue Ray player is a Panasonic DP-UB420.
Users browsing this forum: No registered users and 63 guests
