Repetitives thumbnails BUG for all my audio files
BlueMan
Post Wed Dec 18, 2019 5:52 pm
Hello.
Since a few days, the thumbnails for all my audio files are ALL THE SAME :
This is the same error on Yamaha MusiCast and with Hi-Fi Cast, both using DNLA.
I upgraded to Serviio 2.0, and this problem persists.
How to fix this please ?
Post Fri Dec 27, 2019 12:01 pm
Re: Repetitives thumbnails BUG for all my audio files
there may be an image (the one you see) file in the folder where your music files are. It might be hidden.
BlueMan
Post Wed May 13, 2020 6:05 pm
zip wrote:there may be an image (the one you see) file in the folder where your music files are. It might be hidden.
I checked this, but there is not.
I upgraded with version 2.1 : same bug.
I even removed from the folder the mp3 file containing this image, and all the titles have always this same cover ??!!! Incredible.
I suppressed the folder in Serviio, then recreated it. Same result. Like there was a cache.
Is there a folder where the small thumbnails of the music files are stored ?
[EDIT] : the only solution i have found is :
- Remove in Serviio console the bugged folder.
- Create in Windows explorer a new folder.
- Copy the music files into this new folder.
- Delete the old bad folder.
- In Serviio console, add the new folder
Users browsing this forum: No registered users and 62 guests
