Trial License for 2.0
catalano
Post Fri Jul 26, 2019 2:29 pm
I was running Serviio on a Synology NAS. I had to upgrade to 2.0 because the older version wouldn't run anymore. Was I supposed to get a 15 day trial license for Pro with the upgrade?
Thanks,
Chris
Post Tue Aug 13, 2019 2:22 pm
Re: Trial License for 2.0
yes
catalano
Post Tue Aug 13, 2019 2:37 pm
Ok, where would I find it?
Thank You.
Post Tue Aug 13, 2019 9:33 pm
catalano wrote:Ok, where would I find it?
Thank You.
There's nothing to find. When you install Serviio, and you don't have a license file installed, it provides all Pro features for 15 days. You don't have to do anything to "activate" it.
Riewekooche
Post Thu Jan 09, 2020 9:26 am
In the last days tried Serviio 1.10... and MagicMediaServer.
Then i decided to use Serviio and installed Ver. 2.0...
After scanning a huge library i noticed that there isn't the possibility to try the PRO option.
At least from Installing 1.10 to now are less then 7 days...
Any idea how to get to the PRO-trial without deinstallung/reinstalling?
(I dont want to do the scanning again - took 2 days)
Users browsing this forum: Google [Bot] and 21 guests
