Opus audio file support
TheBashar
Post Thu Oct 15, 2015 3:56 pm
It would be really great if Serviio could serve Opus audio files.
Thanks!
rimkashox
Post Wed Apr 27, 2016 6:20 pm
Re: Opus audio file support
Yes I fully agree, I see a lot of opus audio along with x265.., that is really a shame because it's being used all over the place.. To my knowledge opus is supported by ffmpeg, so it shouldn't be too difficult to add it.. Really waiting for it ! Thanks and keep up the wonderful work.
suchheld
Post Thu Jun 07, 2018 1:44 pm
Please, please, please add opus support. It is the new standard for High Efficiency Audio Coding (surround) and comes often together with new x265 coded videos.
Edit: ffmpeg already support it, I copied the latest static binary into the serviio/lib/ folder and tried some additions in profiles.xml but with no luck :(
Post Thu Jun 07, 2018 7:03 pm
create a ticket on bitbucket and add there some examples of ffmpeg -i for the files.
suchheld
Post Thu Jun 07, 2018 7:37 pm
Done, thanks a lot :)
yahya69
Post Thu Jan 02, 2020 9:46 am
zip wrote:create a ticket on bitbucket and add there some examples of ffmpeg -i for the files.
I saw the ticket on bitbucket was marked as resolved in July. It seems, current serviio still doesn't support Opus. I see it was released prior to the bug being marked as resolved. Do you have a public beta of the next version, just to test it?
Post Sun Jan 12, 2020 8:49 pm
It should be done as a part of 1.10.
Return to Feature requests
Users browsing this forum: Google [Bot] and 15 guests
