Add files from network drive
depechefan
Post Sat Sep 21, 2019 9:04 am
I'm trying to add files to my library using a mapped drive. However I'm only able to select files on the local C: drive. I've modified the Serviio service to run as the local admin account that I'm also using for logging into the server but it still doesn't allow me to select the mapped drive.
How can I change this?
Thanks in advance
/M
Post Sat Sep 21, 2019 9:07 pm
Re: Add files from network drive
depechefan wrote:Hi,
Thanks in advance
/M
Change the Serviio service to run under your user account. The default account that Serviio uses has no network permissions. However, mapped drives are only mapped when the user is logged in. You will have to use the network UNC path: \\share_name\Share_folder.
Paul C
Post Sat Sep 21, 2019 11:40 pm
atc98092 wrote:Change the Serviio service to run under your user account. The default account that Serviio uses has no network permissions. However, mapped drives are only mapped when the user is logged in. You will have to use the network UNC path: \\share_name\Share_folder.
This is useful advice.
I have an external drive that works fine without logging in. But it is not a mapped drive which is different.
depechefan
Post Sun Sep 22, 2019 9:52 am
Well, accessing one of my NAS drives seems to work. Couldn't get my drive connected to a PC to work. But no big deal. I can work around it.
Thanks for the advice.
/M
Post Sun Sep 29, 2019 11:44 am
Try using UNC path rather than mapped drive name
Korben38
Post Mon Jan 20, 2020 10:36 pm
zip wrote:Try using UNC path rather than mapped drive name
I have a similar problem, can you write step by step how and where to do it?
Users browsing this forum: Baidu [Spider] and 24 guests
