Fixed. My fault. I'm an idiot. Upgraded to 1.10.1, ------
n3mmr
Post Wed Jan 29, 2020 8:45 am
After upgrading to 1.10.1, no media file of any type can be played back by any of my renderers.
Bug or something I have missed??
Note I have lots of different Video files, all of which were eminently playable on all my various renderers via Serviio DLNA v 1.6.something.
Playing via network shares works, but not via Serviio.
A short excerpt from the DEBUG log file:
2020-01-29 09:13:37,259 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.174, Profile=Generic DLNA profile, Name=BubbleUPnP Media Renderer'
2020-01-29 09:13:37,259 WARN [ResourceDeliveryProcessor] Invalid request, sending back 400 error
org.serviio.upnp.protocol.http.transport.InvalidResourceRequestException: Invalid incoming request: /resource/2202/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0
at org.serviio.upnp.protocol.http.transport.RequestedResourceDescriptor.<init>(RequestedResourceDescriptor.java:65)
at org.serviio.upnp.protocol.http.transport.AbstractProtocolHandler.getRequestedResourceDescription(AbstractProtocolHandler.java:36)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:65)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:82)
at org.serviio.upnp.webserver.AbstractRequestHandler.handle(AbstractRequestHandler.java:66)
at org.apache.http.protocol.HttpService.doService(HttpService.java:423)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:78)
at org.apache.http.protocol.HttpService.handleRequest(HttpService.java:341)
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:204)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 3
at org.serviio.upnp.protocol.http.transport.RequestedResourceDescriptor.<init>(RequestedResourceDescriptor.java:62)
... 8 more
2020-01-29 09:13:37,350 DEBUG [ServiioHttpService] Incoming request from /192.168.1.174:37412: GET /resource/2202/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [User-Agent: MXPlayer/1.15.9 (Linux; Android 10; sv-SE; Nokia 9 Build/00WW_5_13E),Accept: */*,Range: bytes=0-,Host: 192.168.1.104:8895,Icy-MetaData: 1,Connection: keep-alive]]
2020-01-29 09:13:37,350 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.174
2020-01-29 09:13:37,351 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.174
2020-01-29 09:13:37,352 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.174
2020-01-29 09:13:37,352 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.174, Profile=Generic DLNA profile, Name=BubbleUPnP Media Renderer'
2020-01-29 09:13:37,353 DEBUG [ResourceDeliveryProcessor] Request for resource 2202 and type 'MEDIA_ITEM' received
2020-01-29 09:13:37,359 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2202 (local)
2020-01-29 09:13:37,359 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2202)
2020-01-29 09:13:37,361 DEBUG [VideoDAOImpl] Reading a Video (id = 2202)
2020-01-29 09:13:37,362 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2202, format AVC_MP4_MP_SD_AAC_MULT5 and profile Generic DLNA profile
2020-01-29 09:13:37,363 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2202 (local)
2020-01-29 09:13:37,363 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2202)
2020-01-29 09:13:37,364 DEBUG [VideoDAOImpl] Reading a Video (id = 2202)
2020-01-29 09:13:37,365 DEBUG [VideoDeliveryEngine] Delivering item '2202' for client 'Identifier=192.168.1.174, Profile=Generic DLNA profile, Name=BubbleUPnP Media Renderer'
2020-01-29 09:13:37,366 DEBUG [VideoDeliveryEngine] Delivering file 'Poirot.S13E01.Elephants Can Remember.mp4' in native format
2020-01-29 09:13:37,366 DEBUG [MediaItemDAOImpl] Getting file of media item 2202
2020-01-29 09:13:37,893 WARN [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: \\192.168.1.80\cifs\Video\TV-Series\Poirot-The Complete Seasons 01-13\Poirot.S13E01.Elephants Can Remember.mp4 (Det går inte att utföra den begärda åtgärden på den angivna servern)
Post Sat Feb 01, 2020 6:17 pm
Re: Upgraded to 1.10.1, now no media can be played any longe
I think the URLs changed between the versions - but BubbleUPnP has them cached. Try to somehow delete caches in Bubble and try again.
n3mmr
Post Sun Feb 02, 2020 8:41 am
zip wrote:I think the URLs changed between the versions - but BubbleUPnP has them cached. Try to somehow delete caches in Bubble and try again.
None of my other renderers work either. Some of which definitely don't cache anything.
And how could that result in content listings working but playback resulting in "the requested action cannot be performed on that server"?
Or maybe that could be not too far from the real reason... Hmmm.
n3mmr
Post Sun Feb 02, 2020 1:28 pm
I cleared the BubbleUpNP cache, no change, no videos will play.
n3mmr
Post Wed Feb 05, 2020 3:40 pm
Bubble and my old HW renderers display folders and series/season names, and if you go into a series/season all the episodes are shown but if you try to play an episode, there's a long wait and then a fail.
VLC shows folder names and series/season names and then says "Folder is empty" for all folders.
How do I investigate this?
n3mmr
Post Mon Feb 24, 2020 1:48 pm
OK, I think I tried your suggestion, and it had no effect.
What URL is it that has changed, and how???
NOTE:
My Serviio can no longer be used to play back any om my media files.
I have tried it with a plethora of renderers;
VLC on Android, BubbleUPnP on Android, An old Sony Bluray, an old WD LIVE TV HD, VLC on windows laptop..
All fail.
The renderer profiles seem to be the correct ones.
HELP!
Post Mon Feb 24, 2020 11:35 pm
the URL of the file as served by serviio. I think cleaning bubbleupnp cache should fix that.
n3mmr
Post Tue Feb 25, 2020 9:37 am
zip wrote:the URL of the file as served by serviio. I think cleaning bubbleupnp cache should fix that.
As I have already noted, clearing the BubbleUPnP cache had no effect whatsoever.
Also, my problem is not specific to BubbleUPnP, none of my renderers work.
n3mmr
Post Fri Feb 28, 2020 10:05 am
Any comment, Zip?
Post Mon Mar 02, 2020 7:59 pm
can you post a bit more of the debug log?
n3mmr
Post Tue Mar 03, 2020 1:43 pm
zip wrote:can you post a bit more of the debug log?
I wouldn't know how much more of the log, or further down or further up or what.
I attached the zipped complete log file quoted in the OP.
serviio.zip
Contains the complete serviio log related to one instance of the complaint in this thread.
(74.54 KiB) Downloaded 424 times
n3mmr
Post Thu Mar 12, 2020 8:06 am
Re: Fixed. My fault. I'm an idiot. Upgraded to 1.10.1, -----
The installation of 1.10.1 meant Serviio changed what user it was running as.
Me not being W10 savvy failed to see that.
Zip told me early on, but I didn't really understand how to find out about what user a service was bound to.
Users browsing this forum: No registered users and 58 guests
