Problem with Catalina
vilo1968
Post Fri Feb 07, 2020 3:03 pm
Hi.
I recently installed Serviio on Catalina OS and I can't start the console. I get the following error: Cannot connect to the server, it doesn't seem to be running ... "
I have read in this forum for similar problems and I have implemented what was said there but I have not had a result.
I have cleanly uninstalled Serviio as indicated on the web and reinstalled and I still have the same problem.
I have checked whether the xerces.jar and fmjdbc.jar files exist and they do not exist so I deduce that this is not the problem.
Corrupt database I deduce that it is not since I have reinstalled cleanly and the problem continues.
I have cleanly deleted version 2.0 and installed 1.10.1 to see if this version worked, and the result has been the same.
I transcribe below the file serviio.log
Thank you in advance.
2020-02-07 11:09:33,087 INFO [MediaServer] ------------------------------------------------------------------------
2020-02-07 11:09:33,088 INFO [MediaServer] Serviio DLNA media streaming server v 1.10.1 (rev. 3e5b0ba57122)
2020-02-07 11:09:33,088 INFO [MediaServer] Petr Nejedly 2009-2018
2020-02-07 11:09:33,088 INFO [MediaServer] http://www.serviio.org
2020-02-07 11:09:33,088 INFO [MediaServer] Java 1.8.0_191-Oracle Corporation x86_64
2020-02-07 11:09:33,088 INFO [MediaServer] OS Mac OS X 10.15.3
2020-02-07 11:09:33,088 INFO [MediaServer] File encoding: UTF-8
2020-02-07 11:09:33,127 INFO [MediaServer] Headless mode enabled: true
2020-02-07 11:09:33,127 INFO [MediaServer] User: root
2020-02-07 11:09:33,127 INFO [MediaServer] User home dir: /var/root
2020-02-07 11:09:33,127 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2020-02-07 11:09:33,127 INFO [MediaServer] ------------------------------------------------------------------------
2020-02-07 11:09:33,137 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2020-02-07 11:09:33,154 INFO [DatabaseManager] Using DERBY database language
2020-02-07 11:09:33,398 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Failed to create database 'db', see the next exception for details.
at org.apache.derby.impl.jdbc.EmbedConnection.createDatabase(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.jdbc.InternalDriver$1.run(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:270)
at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:71)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:64)
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:82)
at org.serviio.MediaServer.main(MediaServer.java:127)
Caused by: ERROR XJ041: Failed to create database 'db', see the next exception for details.
at org.apache.derby.impl.jdbc.SQLExceptionFactory.wrapArgsForTransportAcrossDRDA(Unknown Source)
... 22 more
Caused by: ERROR XBM0X: Supplied locale description 'es_419' is invalid, expecting ln[_CO[_variant]]
ln=lower-case two-letter ISO-639 language code, CO=upper-case two-letter ISO-3166 country codes, see java.util.Locale.
at org.apache.derby.impl.services.monitor.BaseMonitor.staticGetLocaleFromString(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.setLocale(Unknown Source)
at org.apache.derby.impl.services.monitor.FileMonitor.setLocale(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.TopService.bootModule(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.createPersistentService(Unknown Source)
at org.apache.derby.impl.services.monitor.FileMonitor.createPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.createPersistentService(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection$5.run(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.createPersistentService(Unknown Source)
... 19 more
2020-02-07 11:09:35,464 ERROR [MediaServer] An unexpected error occurred. Ending the application. Message: null
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:50)
Post Sat Feb 08, 2020 12:16 pm
Re: Problem with Catalina
Looks like a known bug in the DB.
Try to add these 2 lines https://www.serviio.org/forum/viewtopic ... 083#p96980 to serviio.sh as described here: https://serviio.org/index.php?option=co ... e&id=21#q3
vilo1968
Post Mon Feb 10, 2020 1:41 pm
Thank you very much for your reply.
I have added the 2 lines to the seviio.sh file and the error continues.
I will appreciate your help.
Post Thu Feb 13, 2020 11:26 am
can you post your serviio.sh file? also, did you restart the Mac?
vilo1968
Post Thu Feb 13, 2020 12:18 pm
Hi.
I attach my file.
Yes, I restarted the computer (many times).
Thank you
#!/bin/sh
##  Serviio start Script                                                    ##
DIRNAME=`dirname "$0"`
PROGNAME=`basename "$0"`
# Setup SERVIIO_HOME
if [ "x$SERVIIO_HOME" = "x" ]; then
    # get the full path (without any relative bits)
    SERVIIO_HOME=`cd "$DIRNAME/.."; pwd`
fi
export SERVIIO_HOME
JAVA="$SERVIIO_HOME/jre/Contents/Home/bin/java"
# Setup the classpath
SERVIIO_CLASS_PATH="$SERVIIO_HOME/lib/*:$SERVIIO_HOME/config"
# Execute the JVM in the foreground
"$JAVA" -Xmx512M -Xms20M -XX:+UseG1GC -XX:GCTimeRatio=1 -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 -Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade -Dderby.system.home="$SERVIIO_HOME/library" -Dserviio.home="$SERVIIO_HOME" -Dffmpeg.location="$SERVIIO_HOME/lib/ffmpeg" -Ddcraw.location="$SERVIIO_HOME/lib/dcraw" -Dserviio.libraryPollerFrequency=5 -classpath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@"
-Duser.language=es
-Duser.country=ES
vilo1968
Post Thu Feb 20, 2020 8:31 pm
I have a Serviio installation in Mojave and it works perfect. I have compared the files and they are the same ...
I don't understand why Catalina doesn't work ...
Post Mon Feb 24, 2020 11:38 pm
you added then in the wrong place.
try
"$JAVA" -Xmx512M -Xms20M -XX:+UseG1GC -XX:GCTimeRatio=1 -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 -Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade -Dderby.system.home="$SERVIIO_HOME/library" -Dserviio.home="$SERVIIO_HOME" -Dffmpeg.location="$SERVIIO_HOME/lib/ffmpeg" -Ddcraw.location="$SERVIIO_HOME/lib/dcraw" -Dserviio.libraryPollerFrequency=5 -Duser.language=es -Duser.country=ES -classpath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@"
vilo1968
Post Sun Mar 01, 2020 3:25 pm
Thank you! Now it works perfectly!
VooDooVox
Post Thu Feb 23, 2023 2:02 pm
I have the same problem.
it just started after recent security update of Catalina.
I applied this solution but didnt work for me. Do you have any other advice for me too?
TGrosser
Post Thu Mar 28, 2024 10:40 am
For Catalina with installed JDK 11 the SERVIO local JRE does not seem to resolve the SLF4J dependency correctly.
Users browsing this forum: Baidu [Spider], Google [Bot] and 83 guests
