Problem with mkv file
mib182
Post Mon Feb 17, 2020 1:19 pm
I'm using Serviio on Debian 10 server.
Ffmpeg 3.2.4
Java :
java version "1.8.0_201"
Java(TM) SE Runtime Environment (build 1.8.0_201-b09)
Java HotSpot(TM) 64-Bit Server VM (build 25.201-b09, mixed mode)
I watch videos on Samsung TV ( UE46ES7000 ) with dlna client from source, with RJ45 wire.
The Tv profile in serviio console is configured with Samsung TV / player (E/F-series), with default many problems and files not read.
For most of files no problem.
But for MKV files, files can be read, but I can't move forward or backward. The duration of the file is still 7:08:40.
It's a problem cause if a stop reading I can't go where I stopped.
I put here information for files :
Files 1 :
ffmpeg -i /multimedia/file1.mkv
ffmpeg version 3.2.4 Copyright (c) 2000-2017 the FFmpeg developers
  built with gcc 8 (Debian 8.3.0-6)
  configuration:
  libavutil      55. 34.101 / 55. 34.101
  libavcodec     57. 64.101 / 57. 64.101
  libavformat    57. 56.101 / 57. 56.101
  libavdevice    57.  1.100 / 57.  1.100
  libavfilter     6. 65.100 /  6. 65.100
  libswscale      4.  2.100 /  4.  2.100
  libswresample   2.  3.100 /  2.  3.100
Input #0, matroska,webm, from '/multimedia/file1.mkv':
    encoder         : libebml v1.3.9 + libmatroska v1.5.2
    creation_time   : 2019-12-26T16:46:54.000000Z
  Duration: 00:03:45.28, start: 0.000000, bitrate: 4094 kb/s
    Chapter #0:0: start 0.000000, end 225.016000
      title           : (01)00:00:00:000
    Chapter #0:1: start 225.016000, end 225.278000
      title           : (02)00:03:45:016
    Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default) (forced)
      BPS-eng         : 3632118
      DURATION-eng    : 00:03:44.475000000
      NUMBER_OF_FRAMES-eng: 5382
      NUMBER_OF_BYTES-eng: 101914984
      _STATISTICS_WRITING_APP-eng: mkvmerge v37.0.0 ('Leave It') 64-bit
      _STATISTICS_WRITING_DATE_UTC-eng: 2019-12-26 16:46:54
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Stream #0:1(eng): Audio: aac (LC), 48000 Hz, 5.1, fltp (default)
      BPS-eng         : 472470
      DURATION-eng    : 00:03:45.258000000
      NUMBER_OF_FRAMES-eng: 10559
      NUMBER_OF_BYTES-eng: 13303457
Files 2 :
ffmpeg -i /multimedia/file2.mkv
  configuration:
[matroska,webm @ 0x563d026f4540] Could not find codec parameters for stream 3 (Subtitle: hdmv_pgs_subtitle): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[matroska,webm @ 0x563d026f4540] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle): unspecified size
Input #0, matroska,webm, from '/multimedia/file2.mkv':
    title           : John Wick 2014 MULTi VFF 1080p BluRay HDLight AC3 x265-Winks
    encoder         : libebml v1.3.7 + libmatroska v1.5.0
    creation_time   : 2019-05-09T05:51:37.000000Z
  Duration: 01:41:13.12, start: 0.000000, bitrate: 5335 kb/s
    Chapter #0:0: start 0.000000, end 297.714000
      title           : Chapitre 01
    Chapter #0:1: start 297.714000, end 742.074000
      title           : Chapitre 02
    Chapter #0:2: start 742.074000, end 1027.609000
      title           : Chapitre 03
    Chapter #0:3: start 1027.609000, end 1586.293000
      title           : Chapitre 04
    Chapter #0:4: start 1586.293000, end 1960.458000
      title           : Chapitre 05
    Chapter #0:5: start 1960.458000, end 2184.724000
      title           : Chapitre 06
    Chapter #0:6: start 2184.724000, end 2536.242000
      title           : Chapitre 07
    Chapter #0:7: start 2536.242000, end 2733.397000
      title           : Chapitre 08
    Chapter #0:8: start 2733.397000, end 3303.091000
      title           : Chapitre 09
    Chapter #0:9: start 3303.091000, end 3567.730000
      title           : Chapitre 10
    Chapter #0:10: start 3567.730000, end 3973.970000
      title           : Chapitre 11
    Chapter #0:11: start 3973.970000, end 4456.118000
      title           : Chapitre 12
    Chapter #0:12: start 4456.118000, end 4753.165000
      title           : Chapitre 13
    Chapter #0:13: start 4753.165000, end 5250.745000
      title           : Chapitre 14
    Chapter #0:14: start 5250.745000, end 5544.997000
      title           : Chapitre 15
    Chapter #0:15: start 5544.997000, end 6073.120000
      title           : Chapitre 16
    Stream #0:0(fre): Video: hevc (Main 10), yuv420p10le(tv, bt709), 1920x800 [SAR 1:1 DAR 12:5], 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default)
      title           : film2 2014
      BPS-eng         : 4049083
      DURATION-eng    : 01:41:13.067000000
      NUMBER_OF_FRAMES-eng: 145608
      NUMBER_OF_BYTES-eng: 3073794107
      _STATISTICS_WRITING_APP-eng: mkvmerge v33.1.0 ('Primrose') 64-bit
      _STATISTICS_WRITING_DATE_UTC-eng: 2019-05-09 05:51:37
    Stream #0:1(fre): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
      title           : Truefrench
      BPS-eng         : 640000
      DURATION-eng    : 01:41:13.120000000
      NUMBER_OF_FRAMES-eng: 189785
      NUMBER_OF_BYTES-eng: 485849600
    Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s
      title           : Anglais
      BPS-eng         : 640000
      DURATION-eng    : 01:41:13.088000000
      NUMBER_OF_FRAMES-eng: 189784
      NUMBER_OF_BYTES-eng: 485847040
    Stream #0:3(fre): Subtitle: hdmv_pgs_subtitle (default)
      title           : Fr Forces
      BPS-eng         : 1373
      DURATION-eng    : 01:14:36.597000000
      NUMBER_OF_FRAMES-eng: 118
      NUMBER_OF_BYTES-eng: 768647
    Stream #0:4(fre): Subtitle: hdmv_pgs_subtitle
      title           : Fr Full
      BPS-eng         : 11442
      DURATION-eng    : 01:34:04.931000000
      NUMBER_OF_FRAMES-eng: 954
      NUMBER_OF_BYTES-eng: 8074138
    Stream #0:5: Video: mjpeg, yuvj420p(pc, bt470bg/unknown/unknown), 500x700 [SAR 144:144 DAR 5:7], 90k tbr, 90k tbn, 90k tbc
      filename        : poster.jpg
      mimetype        : image/jpeg
Do you have the same problem ? Or have an idea to fix it ?
Post Tue Feb 18, 2020 12:42 am
Re: Problem with mkv file
Transcoded files cannot be fast forwarded, rewound or resumed (trick play), except for very specific players. That example file you listed is H.265/HEVC, which your TV does not support so requires transcoding. It has nothing to do with it being an MKV file. It's the codec that it contains that is the issue. Your audio codec is AAC 5.1, which may or may not also be an issue for the TV. I can't say for sure. Even if your TV could play the video but require audio transcoding, you'd still be unable to use trick play. The second file you posted info about uses AC3 (Dolby Digital), so your TV should support that. But again, it's H.265 video, which your TV doesn't support.
You could try the Roku TV (non-4K) profile and see if that works and offers trick play. It uses HLS transcoding, which on some devices allows trick play.
mib182
Post Tue Feb 18, 2020 2:08 pm
Thanks for the answer.
Now I understand. If codec format is known file is read.
If format is unknown, file is transcoded during watching, and this is why we can't move backward/forward.
I tested the other profile, it's not working.
The was bought in 2012 ... normal x265 not know.
I have to convert files to x264 format.
i'm testing it.
thanks.
Post Tue Feb 18, 2020 3:44 pm
I can't say for certain that your TV supports H.264, but it might. The one certainty would be MPEG-2. The MKV container can be used for practically any codec. That's why it's so popular. :)
mib182
Post Tue Feb 18, 2020 4:25 pm
It supports 264, tested and validated.
But the most important : Now I understand.
Post Tue Feb 18, 2020 5:50 pm
Great! Life is good if you can learn something new every day. :D
Users browsing this forum: No registered users and 51 guests
