remote access from Home Assistant
chris66
Post Mon Nov 04, 2019 2:15 pm
Hi, is it possible to access to Serviio DNLA via frontend like Home Assistant?
I need a remote access to this file:
# Example configuration.yaml entry
media_player:
  - platform: dlna_dmr
    url: http://192.168.0.10:9197/description.xml
What is the exact URL and port I have to write? Thanks.
proUser
Post Thu Feb 20, 2020 6:55 pm
Re: remote access from Home Assistant
excellent question.
Any other way to integrate serviio into homeassistant would be interesting. Any experiences here?
Post Sun Feb 23, 2020 10:24 am
it'd be something like
http://<server_ip>:8895/deviceDescription/<device_uuid>
where device_uuid you can get from the logs. It'd change if the IP address of the server changes
papaleoss
Post Tue Oct 05, 2021 6:02 am
Has anyone made this and could you explain the process? Please share the steps and some easy custom writing files or articles how to do this.
I integrated Serviio DNLA into HomeAssistant successfully. PM me for the details. I've also a Google doc with all steps.
Post Wed Oct 06, 2021 3:03 pm
Might be worth sharing it on the wiki.
boobboo
Post Tue Oct 12, 2021 2:54 pm
@papaleoss - I can't seem to PM you, can you share the Google Doc URL as I am trying the same thing with Home Assistant
Chris
