Re: Profile Samsung HDR UHD 4K 43RU7405 [UE43RU7405UXXC]
Try the NU profile that I created. It will be included in the next update of Serviio, but I don't know when that will happen. In the meantime, copy that file into the settings folder for your Serviio install. Under Windows, that would be C:\Program Files\Serviio\config
viewtopic.php?f=10&t=24892&start=20#p126633
