samsung n series tv profile (i.e., nu 8000, 7100, 6900, etc)
Post Mon Feb 10, 2020 1:39 pm
Re: samsung n series tv profile (i.e., nu 8000, 7100, 6900,
MonaxDK wrote:The only thing is that when browsing from TV, files have two extensions, like mkv.mkv or mkv.mpg
But this is not a big problem, the main thing is that everything works.
Yeah, that's Samsung. Nothing can be done about that. As I've said before, Samsung puts very little effort in their DLNA client, and doesn't really seem to care how well it works. I tried years ago to get them to add some improvements, but crickets.
Manala
Post Wed Feb 26, 2020 3:21 pm
atc98092 wrote:UPDATE 2: OK, by matching MPEG4 video it now works with both clips. Revised user profile attached, and it will be contained in the next Serviio release.
Thanks for the effort to finally get NU series supported. I tried this profile with my NU8000 (changed from Samsung M-series profile) and noticed immediately that soft subtitles and resume playback stopped working. I'm new with profiles and don't really know what I'm doing, but from the first page of this thread I found this profile and merged some lines from that profile to yours and got soft subtitles and resuming working again.
Here's the end result if someone else is missing subs and resuming:
user-profiles.xml
(3.72 KiB) Downloaded 964 times
colo
Post Sat Mar 07, 2020 1:20 pm
Detection regex in user-profiles.xml is wrong it will catch Samsung J models, not N models.
Should be
^[A-Z]{2}\d{2}N[A-Z]?\d{3,4}.*
instead of
^[A-Z]{2}\d{2}J[A-Z]?\d{3,4}.*
in ModelName and User-Agent xml tags
Post Sat Mar 07, 2020 5:51 pm
colo wrote:Detection regex in user-profiles.xml is wrong it will catch Samsung J models, not N models.
Should be
instead of
Good catch. I forgot to change the header when I made the modifications for the N models. I'll send that update to Zip. Thanks!
MonaxDK
Post Fri Mar 13, 2020 8:37 pm
Should be
instead of
Can you please post the updated profile here, because it is not clear when the new version of Serviio will be released.
Post Sat Mar 14, 2020 6:48 pm
This is the profile I've given to Zip for the next release. Right now it's in a user-profile file, but when the next version of Serviio is released it will be in the main profiles file, and this can be removed.
user-profiles.xml
(4.12 KiB) Downloaded 965 times
danielgrant007
Post Sat Jul 25, 2020 5:41 am
Samsung 7 Series NU7100 43" - Flat 4K UHD Smart LED TV
Mounting Type Wall Mount
Brand SAMSUNG
Resolution 4K
Connections Built-in Wi-Fi, HDMI
Color Charcoal Black
But I have a problem with it. It is not Codding the audio in a good way.
can you help me out otherwise i'm planning to change it.
For Business travelers complete guide is available to avail Sri Lanka business visa
Post Sat Jul 25, 2020 6:53 pm
danielgrant007 wrote:Samsung 7 Series NU7100 43" - Flat 4K UHD Smart LED TV
Brand SAMSUNG
Resolution 4K
Don't understand what the problem is. What is it doing/not doing with the audio that you don't like? And we would need to know what the audio codecs in use are. Need more detail.
Previous
