YouTube
Well, youtube is now working. I hope they are finished with their testing.
Re: YouTube
Gone again after one day. I give up on them. They're pushing their new streaming service and I suspect that has something to do with the problems.
Re: YouTube
Is youtube.groovy plugin currently working under v2 ?
Not sure what I am doing wrong.
Presumably the online source are defined as web resources/video ?
Can someone post a couple of working links for me please.
Serviio Pro v2.1, DBpoweramp & Asset UPnP (registered), HP Elitebook, HP Pavilion, Windows 10 Pro, Linn Majik DS/1, NEET AirstreamPro renderer, Naim NAC72/NAP140 (x2), Celestion Ditton 25 and Spendor A5 speakers, WD TV Media Player (x2), Panasonic Blu-ray DMP-BDT360, Panasonic TV, Amazon Fire 7 HDX, BubbleUPnP app, Qobuz Studio Hi-Res streaming.
Re: YouTube
The youtube plugin was working with V2 until youtube made their most recent changes. They added more adverts and a premium streaming service which is a paid service. Serviio has been the only server that I used for years. I haven't used any others. I will check the forum on others to see if they are broke as well.
Re: YouTube
I've uploaded a new version of the plugin.
It doesn't work with all videos (some use encrypted signature which I haven't got to code around yet), but hopefully works for most videos.
Petr
Help translate Serviio
Re: YouTube
Thank you Zip! It works with all that I tested so far.
My primary source of on line entertainment is back. I actually use this more than Amazon and Directv.
Re: YouTube
Thank you, Petr!
I watch Youtube content only via TV and only in your plugin for Serviio
Other methods are inconvenient for me.
Serviio 1.10.1 (Pro), Synology DS1515+
Re: YouTube
Sorry to say that I had an update to windows 10 last week and youtube via servio hasn't worked since. I still works under windows 7.
Re: YouTube
Thanks ZIP for the plugin update!
Re: YouTube
Zip,
For me, the plugin is not working again.
Re: YouTube
I don't expect to get a fix for this any time soon. I would personally give youtube some time to make all of their changes/updates to get the platform stable before wasting much time on it.
Re: YouTube
Just to clarify, is there currently a way to warch a YouTube video via Serviio? I have spent 2+ hours reading this and other forums but there are no clear instructions on how to set this up in 2020. @zip please provide a download link to the youtube plugin as its impossible to find on this forum.
Re: YouTube
Instructions and the latest plugin are in the first post in this thread. The plugin is near the end of the post.
Re: YouTube
Good Day All.
I hope all are safe from Covid-19.
The last Youtube changes are allowing the latest Serviio Youtube plugin to work again.
Re: YouTube
In answer to a private message that I received. I am posting here for everyone to see. The plugin still isn't fully functional. I run the server on windows 10 and windows 7 systems. The thumbnail for one or two playlists might show up but the contents of the playlists are missing.
Re: YouTube
Youtube is working again under windows 7 but not under windows 10. I had this situation once before.
Re: YouTube
When adding a playlist it only shows the first clip?
https://www.googleapis.com/youtube/v3/p ... 699743BD19
Re: YouTube
DVD Listing wrote:Zip,
Same here,
2020-04-08 22:14:18,172 WARN [FeedUpdaterWorker] An error occured while parsing the online resource https://www.googleapis.com/youtube/v3/p ... CG2QkzYr45, waiting for expiry time to try again: Unexpected error while invoking plugin (YouTube): Text must not be null or empty
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (YouTube): Text must not be null or empty
It was working last week..
Version 2.0, on Debian, with the latest YouTube plugin ( from the first page).
Re: YouTube
Youtube has actually been having problems since the middle of last year. They are making numerous changes to monitize their services. They now have a pay/streaming service and are now inserting adverts at the beginning of and in the middle of videos. I strongly suspect that they are not done with their changes. The plugin might be changed to handle the current conditions only to have youtube break it again.
Re: YouTube
I had the same error on logs:
To solve I have added my own APIKEY from my Google Developer Account.
The problem is that the current APIKEY included into the file "Youtube.goovy"
reaches the limit of 10000 calls per day, because all of us are been using this APIKEY.
Solution:
1. I have had to learn how to create my own APIKEY on Google and activate it.
https://www.slickremix.com/docs/get-api-key-for-youtube/
2. Then I have edited the Youtube.groovy file replacing api_key with mine.
This works form me!
Now the Serviio.log file only shows this warning: on every online resource, but it captures the online source.
Thanks!
[FeedUpdaterWorker] An error occured while parsing the online resource 'https://...', will try again soon: Unexpected error while invoking plugin (YouTube): Text must not be null or empty
Solution:
This works form me!
[WebResourceParser] Plugin YouTube returned no value for resource item 'null'
Thanks!
