Finding File name from Series name/episode name??
n3mmr
Post Mon Mar 30, 2020 2:14 pm
I discovered I had a Series called Mission X in my Media sever.
So I troed to find where the files were, so I could delete them.
However, nothing obvious shows up???!!!?!?!
Is there a wasy to find the actual video file from knowing the series/episode name?
Post Mon Mar 30, 2020 4:23 pm
Re: Finding File name from Series name/episode name??
From Serviio? No, there's no way I have found. Since I have Plex installed on the same computer, and it does offer file information, that's what I use if I can't find the file. Why do I have Plex? Because when I travel I take a Roku player with me and it can connect to my Plex server through the hotel WiFi. Easier than messing with MediaBrowser when I just want to lie on the bed and watch something. But I never touch Plex on my home network, as I far prefer using Serviio to feed my various players at home.
freaknik
Post Mon Mar 30, 2020 5:09 pm
Look man I don't go to Atlantic City often I was using plex, hit a crack pipe with the midget from the Jackass show on mtv, was a crazy weekend don't judge...
Post Mon Mar 30, 2020 6:11 pm
Freaknik, what is that all about?
For the OP, you might be able to determine the file name/location by digging though the Serviio log. I just looked at mine and it does identify when new files are added
Added file 'E:\Video_3\In Old Chicago (1938).mkv' (title: In Old Chicago) to Library
So do a search for Mission X and see if you can find the line that adds the file. More than likely it's mis-identified some other title with that name.
n3mmr
Post Tue Mar 31, 2020 10:05 pm
atc98092 wrote:Freaknik, what is that all about?
I think Freaknik was smoking his left nose thru his arse...
Re my Q, I could NOT find the string Mission X in the log files.
Post Tue Mar 31, 2020 10:19 pm
Has your log file rolled over, meaning that there's more than one serviio.xxx file in that folder? Serviio starts a fresh log at 5 MB size, and renames the .txt to a number. Those other files are still text files, and you can look through them as well. That string should be in one of them.
n3mmr
Post Wed Apr 01, 2020 11:22 am
atc98092 wrote:Has your log file rolled over, meaning that there's more than one serviio.xxx file in that folder? Serviio starts a fresh log at 5 MB size, and renames the .txt to a number. Those other files are still text files, and you can look through them as well. That string should be in one of them.
Of course I knew that, and I checked ALL log files.
Problem with Mission X disappeared, it was an error in looking up metadata on thetvdb.
Finding the media file from the browser entry name is still interesting.
Users browsing this forum: Baidu [Spider] and 32 guests
