profile Samsung QE65Q90RATXXC
jocker50
Post Wed Apr 01, 2020 9:29 am
Good morning all
I bought a new samsung QE65Q90RATXXC television but I do not find a profile in serviio which corresponds to this model, and moreover impossible to read the dts track and the avi file !!
will there be a servio 2 update for this tv ?? if not a person can create a profile which corresponds?
a big thank you in advance.
Cordially.
Post Wed Apr 01, 2020 1:31 pm
Re: profile Samsung QE65Q90RATXXC
It's extremely difficult to create a profile for a device one doesn't have access to. For starters, try using different profiles to see how they work. That TV is 4K, so try the Roku 4K TV profile. The DirecTV profile transcodes everything, so that's a good test to see if anything plays.
If you find an existing profile that works for you, great. If even the best working profile is missing something, then we can work from the one that works.
jocker50
Post Thu Apr 02, 2020 11:56 am
Hello, thank you for your response.
I tried the roku tv 4k profile and the result and not at all, the unread files are read now.
thank you again for your help.
Cordially.
