Servio Icon not visible in Network Places
sjbraid
Post Wed Apr 08, 2020 3:57 am
Hello all,
I am running Servio Pro 2.0 on Windows10 Home Editon. The yellow Servio Icon (folder) used to appear in Network Locations, when connecting to a media server. You could then click on the icon to make sure that the server is reading the USB Folder that is set up in the applications share folder option.
It no longer does that. I have re-installed Servio, but the problem still persists. I have included an image file. Any help would be tremendously appreciated. This is a wired network, and Servio is looking at a folder on USB Drive that is connected to the same computer that is running Servio.
This is an image that shows where the Servio DLNA Icon used to appear.
Servio Trouble.jpg (138.23 KiB) Viewed 6416 times
Post Wed Apr 08, 2020 12:49 pm
Re: Servio Icon not visible in Network Places
I have two Serviio computers on my network (Server and Media), but I only see Media when I look at that location from Server. I don't know if it's always been that way, but the one that doesn't appear still works fine streaming media. If your Serviio is still available to your networked players, then there's likely nothing to worry about.
sjbraid
Post Wed Apr 08, 2020 10:00 pm
Thank you Dan. Yes Servio is working, it's just acting a bit differently.
Users browsing this forum: Baidu [Spider], Google [Bot] and 19 guests
