Samsung RU7170
xxstyler20xx
Post Wed Apr 08, 2020 5:59 pm
Samsung RU7170
Hello do anyone have a device / transcoding profile for Samsung RU 7 Series?
Post Wed Apr 08, 2020 6:08 pm
Re: Samsung RU7170
There will be an NU profile in the next version of Serviio, although it has little difference to the existing J series profile. My guess is the NU profile will likely work fine. Here's a link to a user-profiles.xml file with it, but you'll have to remove it from your config file when you update because the profile has the same name in the upcoming release, and you can't have two profiles with the same ID name.
viewtopic.php?f=10&t=24892&start=20#p126633
xxstyler20xx
Post Wed Apr 08, 2020 7:40 pm
Re: Samsung RU7170
Thank you very much!
*updated the xml and it works perfect !*
