Serviio 2.0 Last Viewed still not updating
I did a uninstall, and reinstalled 1.10 and last viewed works again. I see in the forum that others have had the same issue. Is this going to be fixed?
zip wrote:The function is per User. So in order to see it on multiple devices you have to assign the same User to multiple devices (either via MediaBrowser / ServiiGo login) or by assigning a user to the device in the Status tab.
dlzc wrote:zip wrote:The function is per User. So in order to see it on multiple devices you have to assign the same User to multiple devices (either via MediaBrowser / ServiiGo login) or by assigning a user to the device in the Status tab.
We have to supply a password for a user. How does a TV or blueray player have to supply such a password? [Confirming, this fails on a Sony Blue-Ray player acting as a media server. Shows "no content".]
If we define a simple account with a simple password, how do we keep this account from being used by someone outside, if we want to leave the "remote" ports open (for when I travel)?
atc98092 wrote:Your test that shows no content, remember that when you assign a user account to a player that user account needs specific permission to access your media. If you create a user account, but do not give that user account permission to your shared library locations, they won't see anything.
