Unsuported File in PS3, though, is mp4
individual
Post Tue Apr 12, 2011 8:20 am
NAS> ffmpeg -i Dead\ Space\ Aftermath\ 2011.mp4
  built on Apr  8 2011 17:16:26 with gcc 4.2.3
  configuration: --arch=arm --enable-armv5te --prefix=/opt --extra-cflags=-I/opt/include --extra-ldflags=-L/opt/lib --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Dead Space Aftermath 2011.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isom
    creation_time   : 2011-04-10 15:00:25
  Duration: 01:17:39.61, start: 0.000000, bitrate: 4050 kb/s
    Stream #0.0(und): Video: h264, yuv420p, 1280x528 [PAR 1:1 DAR 80:33], 3407 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
      creation_time   : 2011-04-10 10:01:17
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 6 channels, s16, 448 kb/s
      creation_time   : 2011-04-10 15:02:22
    Stream #0.2(eng): Audio: ac3, 48000 Hz, 2 channels, s16, 192 kb/s
      creation_time   : 2011-04-10 15:02:40
NAS: DS712+, 2x Seagate ST2000DL003
DLNA Server: Synology, Serviio, Twonky, Plex
DLNA Player: Raspberry Pi Raspbmc
DLNA Tablet: Yatse
Post Tue Apr 12, 2011 8:45 am
Re: Unsuported File in PS3, though, is mp4
Could you post MediaInfo result of your file to check h264 Profile level?
individual
Post Tue Apr 12, 2011 9:47 am
Re: Unsuported File in PS3, though, is mp4 - MediaInfo
Complete name                    : \\nas\video\Movies\Dead Space Aftermath 2011\Dead Space Aftermath 2011.mp4
Format                           : MPEG-4
Format profile                   : Base Media
Codec ID                         : isom
File size                        : 2.20 GiB
Duration                         : 1h 17mn
Overall bit rate                 : 4 051 Kbps
Encoded date                     : UTC 2011-04-10 15:00:25
Tagged date                      : UTC 2011-04-10 15:00:25
Format profile                   : High@L3.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 6 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 1h 17mn
Bit rate mode                    : Variable
Bit rate                         : 3 409 Kbps
Maximum bit rate                 : 29.2 Mbps
Width                            : 1 280 pixels
Height                           : 528 pixels
Display aspect ratio             : 2.40:1
Frame rate mode                  : Constant
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.210
Stream size                      : 1.85 GiB (84%)
Title                            : SureNdrA-ExtraTorrentRG
Writing library                  : x264 core 114 r1913 5fd3dce
Encoding settings                : cabac=1 / ref=6 / deblock=1:1:1 / analyse=0x3:0x133 / me=hex / subme=7 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3409 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.60
Encoded date                     : UTC 2011-04-10 10:01:17
Tagged date                      : UTC 2011-04-10 15:03:04
Audio #1
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : ac-3
Duration                         : 1h 17mn
Bit rate                         : 448 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 249 MiB (11%)
Language                         : English
Encoded date                     : UTC 2011-04-10 15:02:22
Audio #2
Format                           : AC-3
Codec ID                         : ac-3
Duration                         : 1h 17mn
Bit rate                         : 192 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Bit depth                        : 16 bits
Stream size                      : 107 MiB (5%)
Language                         : English
Encoded date                     : UTC 2011-04-10 15:02:40
DLNA Tablet: Yatse
Post Tue Apr 12, 2011 10:40 am
Some Encoding settings on your x264 is probably not compatible with your PS3, I don't know exactly what are the good setting but when googling we could found information:
If you compare your settings with one working you will found differences:
Working
Writing library : x264 core 66 r1097M e404f35
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5739 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Not working
b_pyramid=2 is probably one problem
