YouTube
Ellesworth
Post Sun Apr 12, 2020 8:22 pm
Re: YouTube
Thanks to evryone involved! This now works a charm for me, with my own API on Serviio 2.0 and Win10
RaNd
Post Sun Apr 12, 2020 8:48 pm
Re: YouTube
Thanks, changing the API key did thw trick!
On Debian 9, v2.0
mame32 wrote:I had the same error on logs:
[FeedUpdaterWorker] An error occured while parsing the online resource 'https://...', will try again soon: Unexpected error while invoking plugin (YouTube): Text must not be null or empty
To solve I have added my own APIKEY from my Google Developer Account.
The problem is that the current APIKEY included into the file "Youtube.goovy"
final api_key = "AIzaSyCbFQoC....SqGVE243q0"
reaches the limit of 10000 calls per day, because all of us are been using this APIKEY.
Solution:
1. I have had to learn how to create my own APIKEY on Google and activate it.
https://www.slickremix.com/docs/get-api-key-for-youtube/
2. Then I have edited the Youtube.groovy file replacing api_key with mine.
This works form me! :D
Now the Serviio.log file only shows this warning:
[WebResourceParser] Plugin YouTube returned no value for resource item 'null'
on every online resource, but it captures the online source.
Thanks!
angelodl78
Post Tue Apr 21, 2020 10:15 pm
Re: YouTube
I have copied the .groovy file in the plugin folder + added a couple of youtube links following the guide on the 1st post - but nothing shows up on the media browser and in the log I can see the following error:
2020-04-21 23:51:50,753 WARN [FeedUpdaterWorker] An error occured while parsing the online resource https://www.googleapis.com/youtube/v3/v ... ostPopular, waiting for expiry time to try again: Error during feed reading. Message: URL 'https://www.googleapis.com/youtube/v3/videos?chart=mostPopular' returned status code '400'
org.serviio.library.online.metadata.OnlineResourceParseException: Error during feed reading. Message: URL 'https://www.googleapis.com/youtube/v3/videos?chart=mostPopular' returned status code '400'
at org.serviio.library.online.feed.FeedParser.parse(FeedParser.java:109)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:185)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:207)
at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:194)
at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:100)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: org.serviio.util.HttpConnectionException: URL 'https://www.googleapis.com/youtube/v3/videos?chart=mostPopular' returned status code '400'
at org.serviio.util.HttpClient.retrieveStreamFromConnection(HttpClient.java:203)
at org.serviio.util.HttpClient.retrieveBinaryFileFromURL(HttpClient.java:89)
at org.serviio.util.HttpClient.retrieveBinaryFileFromURL(HttpClient.java:105)
at org.serviio.library.online.feed.FeedParser.parseFeedStream(FeedParser.java:120)
at org.serviio.library.online.feed.FeedParser.parse(FeedParser.java:89)
I have just installed serviio on my lubuntu server 18.04, and the youtube bit would be essential for me.
How can I fix it?
MarkRoy
Post Wed Apr 22, 2020 6:27 am
Re: YouTube
Since YouTube has implemented reCAPTCHA the YouTube.Groovy has stopped working. Until/unless the developer of YouTube.Groovy uncovers a way to deal with the reCAPTCHA issue.. this .groovy will not work and has not worked for more than two years now.
angelodl78
Post Wed Apr 22, 2020 11:28 am
Re: YouTube
MarkRoy wrote:Since YouTube has implemented reCAPTCHA the YouTube.Groovy has stopped working. Until/unless the developer of YouTube.Groovy uncovers a way to deal with the reCAPTCHA issue.. this .groovy will not work and has not worked for more than two years now.
Thanks for the reply, at least I know it now.
Is there an alternative way to get YouTube videos in servizio somehow?
Post Wed Apr 22, 2020 1:04 pm
Re: YouTube
It's highly unlikely there's any workaround for reCAPTCHA. After all, it's specifically designed to require human interaction to pass through. With the number of spam posts I delete on this site daily, I hope there is not a way around it. It's bad enough now, so we just have to accept that we can't access sites like YouTube any longer.
Samsung NU7100 4K TV, Samsung JU7100 4K TV, Sony BDP-S3500, Sharp 4K Roku TV, Insignia Roku TV, Roku Ultra, Premiere and Stick, Nvidia Shield, Yamaha RX-V583 AVR.
Primary server: Intel i5-6400, 8 gig ram, Windows 10 Pro, 22 TB hard drive space | Test server Windows 10 Pro, AMD Phenom II X4 965, 8 gig ram
RaNd
Post Wed Apr 22, 2020 2:31 pm
Re: YouTube
Since we are using the API I don't think that we are going to have an issue with the reCAPTCH.
After changing to my private API key, I have 0 issues.
Post Wed Apr 22, 2020 8:51 pm
Re: YouTube
RaNd wrote:Since we are using the API I don't think that we are going to have an issue with the reCAPTCH.
That makes sense. You would expect the API to not require it.
DVD Listing
Post Wed Apr 22, 2020 9:17 pm
Re: YouTube
RaNd wrote:Thanks, changing the API key did thw trick!
On Debian 9, v2.0
Solution:
Thanks!
I have created my own API key as listed in solution 1. above.
And I have done steps 1 - 8 on that web page.
But I cannot find the youtube webpage stated in step 9 to insert my APIKey.
Can anybody help me out?
Post Wed Apr 22, 2020 9:22 pm
Re: YouTube
I don't think you use step 9. I believe you take the API key you created and add it to the youtube.groovy file in place of the key that's already contained in the file.
DVD Listing
Post Thu Apr 23, 2020 4:47 pm
Re: YouTube
Thanks for the reply @atc98092.
Well, the process didn't work for me.
I followed the process exactly.
I see the folders of the channels I subscribe to (as before), but still no contents within the folders :evil:
RaNd
Post Thu Apr 23, 2020 5:11 pm
Re: YouTube
DVD Listing wrote:Thanks for the reply @atc98092.
You take the API key from step 8 and you use it the the YouTube.groovy file, replacing the API key there.
line 53,
final api_key=Your_New_API_KEY
"Almost done, wait for google to create your new project and you should see the screen below where you can copy your API Key."
norm
Post Sun May 03, 2020 6:59 pm
Re: YouTube
RaNd wrote:You take the API key from step 8 and you use it the the YouTube.groovy file, replacing the API key there.
line 53,
@RaNd: Thanks for your and Zip's work on this. Works fine for me. Register for my own API key, pop it in the Youtube.groovy file, put the updated Youtube.groovy in the plug-ins folder and off you go :)
MarkRoy
Post Mon Jul 06, 2020 3:23 pm
Re: YouTube
Jumped through all the hoops, created a project and got my own API Key.
Swapped it out for the "Serviio" Key in Youtube.Groovy...
Wait for it...
Voila!! Youtube online service working again! HOORAY!!!
Previous
Return to Available plugins
