How to setup the folders?
widewings
Post Wed Apr 13, 2011 8:43 am
I have installed Serviio 0.5.2 on a FreeNAS 0.72. I manage to make serviio.sh to run and I can see the serviio server at my Sony TV. Unfortunately I can't run serviio-console.sh. My question is how can I point to serviio where my files are located. Thanks a lot for the help.
Post Wed Apr 13, 2011 8:53 am
Re: How to setup the folders?
You can either run the console remotely (http://www.serviio.org/component/content/article/21#q2) or install php UI (viewtopic.php?f=17&t=1310)
widewings
Post Thu Apr 14, 2011 6:31 am
hi zip, thanks a lot for the reply. I've read the whole thread on the link. It just created more questions for me and softwares that I don't have. I think I will stick to making the serviio-console.sh working.
Just wondering if anybody can help me why my console is not working
freenas:/mnt/buffer/serviio/bin# sh serviio-console.sh
Exception in thread "main" java.lang.ExceptionInInitializerError
        at com.sun.java.swing.plaf.gtk.GTKLookAndFeel.getGTKStyleFactory(GTKLookAndFeel.java:1539)
        at com.sun.java.swing.plaf.gtk.GTKLookAndFeel.loadStyles(GTKLookAndFeel.java:1503)
        at com.sun.java.swing.plaf.gtk.GTKLookAndFeel.initialize(GTKLookAndFeel.java:1370)
        at javax.swing.UIManager.setLookAndFeel(UIManager.java:536)
        at javax.swing.UIManager.setLookAndFeel(UIManager.java:581)
        at org.serviio.ui.view.swing.SwingHelper.initSwing(SwingHelper.java:51)
        at org.serviio.console.ServiioConsole.main(ServiioConsole.java:90)
Caused by: java.awt.HeadlessException:
No X11 DISPLAY variable was set, but this program performed an operation which requires it.
        at sun.java2d.HeadlessGraphicsEnvironment.getDefaultScreenDevice(HeadlessGraphicsEnvironment.java:64)
        at com.sun.java.swing.plaf.gtk.PangoFonts.<clinit>(PangoFonts.java:43)
        ... 7 more
I already installed java and doubled check that it is there
freenas:/mnt/buffer# pkg_add -v java.tbz
Requested space: 109M bytes, free space: 16G bytes in /var/tmp/instmp.iUChfa
pkg_add: package 'diablo-jre-1.6.0.07.02' or its older version already installed
pkg_add: 1 package addition(s) failed
any idea would be much appreciated.....
I attached a serviio log as well.
(57.29 KiB) Downloaded 972 times
widewings
Post Thu Apr 14, 2011 7:55 am
in case somebody is also experiencing my problem......
if you have a windows computer..... download the windows version of serviio but install only the console.....
then edit the file....ServiioConsole.exe.vmoptions and put this inside....
-Dserviio.remoteHost=192.168.x.x
192.168.x.x is the server ip address
then on the server side.... edit serviio.sh then replaced this line onto yours
# Setup Serviio specific properties
JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME -Dffmpeg.location=/usr/local/bin/ffmpeg -Dserviio.remoteHost=192.168.x.x"
192.168.x.x is the server ip address same as above.....
thanks for the help zip.... I read to fast and not really understanding it that is why ..... anyway problem solved..... :D
