Cyberghost vpn sometimes changes the dedicated IP address of
tullynuevo
Post Fri May 08, 2020 2:18 pm
Cyberghost vpn sometimes changes the dedicated IP address of Serviio (home network). Servio is installed on windows 10. After that, the clients can no longer find the server. How can I prevent the permanently assigned ip from the home network from being changed by a VPN IP? Can someone help me ?
(Internet access is not necessary)
Post Fri May 08, 2020 5:04 pm
Re: Cyberghost vpn sometimes changes the dedicated IP addres
That sounds like something that you need to ask Cyberghost. There's nothing that can be done via Serviio.
tullynuevo
Post Fri May 08, 2020 7:02 pm
Thanks for quick response. I will ask cyberghost and give a feedback. Perhaps other one has a similar problem
tullynuevo
Post Wed May 13, 2020 3:40 pm
Solution:
It seems windows was the reason.
See also viewtopic.php?f=10&t=10629&p=70628#p70628
"Microsoft have changed the default behaviour of this in Windows 8 / Windows Server 2012. To allow interactive services, you need to find the registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Windows and change NoInteractiveServices from 1 to 0.
once this is done, start the service, re-install the App, reboot, et voila!"
This works also on win10. I've been watching the behavior for days it works
ThomasGreent
Post Fri Nov 12, 2021 7:00 am
Because I'm very vigilant about all my data on the Internet, I always try to sit on the Internet anonymously. I don't want to be tracked by various secret services or just some people knowing where I am at a given moment. So I always try to use VPN, even when I am out of the country and far from home. Even when I try to connect to any Wi-Fi network, the safest way to do it is to use a VPN. Well, most of the time, I use a VPN at home when I'm watching home theater. I always try to choose the best addons https://bestvpnprovider.co/the-best-kod ... out-of-it/ with which to watch videos or movies.
Users browsing this forum: No registered users and 132 guests
