Serviio 2.0 issue: m4a files can't be added to library
PlutoniaS
Post Fri Jun 07, 2019 8:57 am
it seems like 2.0 version has a real issue with m4a files:
see my scenarios & steps (I'm using Win7):
1. 2.0 upgrade above 1.10.1:
- after upgrade is successfully completed = status page shows that library contains valid number of files (=1000 as an example)
- if I try to add any m4a file - nothing happens - only old (from previous 1.10.1 version) number is shown = 1000
- if I try to add any mp3, flac - fine! files added to library = 1001 files shown
2. direct install version 2.0
- uninstall 1.10.1 & restart win
- install 2.0 - success
- add valid path to my music files - success
- try to refresh - only mp3, flac, play_lists etc were added - NO m4a files were added
Could you please try to fix it ASAP? - almost all my media library is not accessible :( so I'm still using now 1.10.1
thanks!
Post Mon Jun 10, 2019 8:58 am
Re: Serviio 2.0 issue: m4a files can't be added to library
can you post detailed log?
PlutoniaS
Post Wed May 20, 2020 10:27 am
has issue I described above been fixed in 2.1 version?
sorry - I'm not able to deploy 2.0 to provide logs as you asked above - so asking you to check if possible
thanks!
freaknik
Post Wed May 20, 2020 3:07 pm
He can't help you without a log and it's not an issue for anyone else.
PlutoniaS
Post Thu May 21, 2020 12:00 pm
I've just tried 2.1 version on the same PC - works good - seems like issue is gone :)
thanks!
