Volumes no longer found on Mac
Godsbusy
Post Thu May 28, 2020 10:03 pm
Just updated, and don't know why this new version (2.1) cannot find any of my external drives where I have my media. It seems to recognize that I have video media (on the start up page it shows that there are videos, but when you go to the library and shared folders - it has errors (little error triangles beside all the paths to the media) Trying to edit to find a new path, to the volumes - leads to an endless loop, only showing the Macintosh HD, and no volumes. Any idea what the solution to this is??
Post Thu May 28, 2020 10:23 pm
Re: Volumes no longer found on Mac
You are the second one today to report that. From the description, it sounds like there's a permissions issue between Serviio and your media folders. I have no experience with MacOS, so can't begin to guess where to look. With Windows, I usually suggest changing the user account the Serviio service uses, since the default user account used can't access some locations. Most likely it's something similar with the MacOS. I also seem to remember a couple of users mentioning a recent MacOS update caused issues with Serviio as well. Again because of my lack of Mac knowledge, I didn't read them too closely. Perhaps there's another thread here that might mention it.
The Wiki does have some FAQs for using the MacOS: https://wiki.serviio.org/doku.php?id=mac_install
Godsbusy
Post Thu May 28, 2020 10:47 pm
I seemed to find a fix, I went to the System Preferences - Security and Privacy - Privacy - Full Disc Access - and deleted Java in "full Disc Access" - updated Java and re-added it to the Full Disc Access, and it now seems to be seeing the volumes, so I'm hoping this is a fix.
I will delete the old mapping and remap and let you know if it works.
The key was you advising me that it had to do something with permissions.
Post Thu May 28, 2020 11:05 pm
Godsbusy wrote:I seemed to find a fix, I went to the System Preferences - Security and Privacy - Privacy - Full Disc Access - and deleted Java in "full Disc Access" - updated Java and re-added it to the Full Disc Access, and it now seems to be seeing the volumes, so I'm hoping this is a fix.
I appreciate the update. I'll pass it along to the other user.
Godsbusy
Post Thu May 28, 2020 11:10 pm
Yes - this seemed to have worked - everything is working as it was before the update!
Tranquillado
Post Wed Aug 09, 2023 9:15 pm
Godsbusy wrote:Yes - this seemed to have worked - everything is working as it was before the update!
I’ve searched all day for a solution why Serviio suddenly can’t see my external drives, and it turns out I accidentally deleted Java from my Full Disk Access. I did what you did and all is well.
THANK YOU!
Users browsing this forum: Google [Bot] and 23 guests
