Subtitles support
honeycock
Post Fri Feb 26, 2010 10:01 pm
Subtitles support
Hi there!
I have just started using Serviio with my Samsung 40B7070, and it works like a charm. By far the easiest and simplest to use DLNA server out there.
I watch most of my movies with subtitles, and .srt is working fine. I was wondering if there are any plans of widening the compatibility to other formats as well, since I know that at least the Samsung TVs natively support quite a wide range of subtitles when playing from USB.
Appreciate your effort, keep up the good work!
Post Fri Feb 26, 2010 10:15 pm
Re: Subtitles support
yeah, what types you're after exactly?
honeycock
Post Sat Feb 27, 2010 9:53 am
Mainly MicroDVD (.sub) -format. I know there are a bunch of handy subtitle editing software to change formats out there, but going through 500+ subtitles and changing them one by one doesn't seem very practical...
piperos
Post Sun Mar 28, 2010 8:58 pm
how did u get your srt working? all videos play but srt's not show up
i got a mac / samsung LE40 with dlna.... hooked up with a utp
Post Tue Mar 30, 2010 9:58 pm
You have to select Samsung profile and name the srt file with the same name as the video file
piperos
Post Tue Mar 30, 2010 10:18 pm
i've done that zip but it doesnt seem to work... any other ideas i should check ? :(
Post Wed Mar 31, 2010 5:40 am
Ifound that some srt files seem 'corrupted' to the TV. Did you try more videos? Also give an example of the video and srt file names you're using.
jmleon
Post Fri Apr 16, 2010 4:10 pm
Very good program!!! I have a mac (snow leopard). I ve installed serviio yesterday and all was ok, but I cant get subtitles srt. I know srt file name have to be the same video file but...
I watch "lost" in english but Im spanish...I need subtitles!!!
Could you help me? Thank you very much.
jmdlp
jmleon
Post Fri Apr 16, 2010 4:19 pm
Ooohhh! the same srt subtitles can watch them by usb....
jmleon
Post Fri Apr 16, 2010 4:24 pm
Sorry, Ive a Samsung TV, exactly LE40C650...
Post Fri Apr 16, 2010 5:09 pm
Are you using the Samsung renderer profile (in console)?
jmleon
Post Fri Apr 16, 2010 5:44 pm
Yes of course! it works very good! except subtitles..
jmleon
Post Fri Apr 16, 2010 6:14 pm
Its a new TV. Samsung C650 series. May be something is diferent, but I know this TV support srt by dlna.
Post Sat Apr 17, 2010 11:11 am
Hmm.. for this towork I need someone to capture the HTTP packets going from the Samsung PC Share manager to your TV when you try to play a movie with subtitles (and it's working). Not sure if you can do it?
Also can you post log (with detail on) of when you try to play a movie with subtitles on Serviio?
jmleon
Post Sat Apr 17, 2010 10:41 pm
this is serviio.log, I tried to see Lost with srt subtitles.
00:10:38,916 INFO [MediaServer] ------------------------------------------------------------------------
00:10:38,942 INFO [MediaServer] Serviio DLNA media streaming server v 0.3.1
00:10:38,942 INFO [MediaServer] Petr Nejedly 2009-2010
00:10:38,942 INFO [MediaServer] http://www.serviio.org
00:10:38,942 INFO [MediaServer] Java 1.6.0_17-Apple Inc.
00:10:38,942 INFO [MediaServer] OS Mac OS X x86_64 10.6.3
00:10:38,943 INFO [MediaServer] File encoding: UTF-8
00:10:38,943 INFO [MediaServer] ------------------------------------------------------------------------
00:10:39,409 INFO [ORBServer] Starting Corba server exposed on localhost:23423
00:10:39,410 INFO [NamingService] Starting Corba Naming service on port 23423
00:10:42,855 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
00:10:44,862 INFO [ProfilesDefinitionParser] Parsing Profiles definition
00:10:45,060 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
00:10:45,074 INFO [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro' (id=2)
00:10:45,114 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
00:10:45,123 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
00:10:45,460 INFO [WebServer] WebServer starting on port 8895
00:10:45,479 INFO [Device] Created UPnP Device with UUID: 83403509-60a4-3ac0-bae1-94340baf2344, bound address: 192.168.1.2
00:10:45,507 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
00:10:45,508 INFO [DiscoverySearchListener] Starting DiscoverySearchListener using interface 192.168.1.2
00:10:45,508 INFO [EventDispatcher] Starting EventDispatcher
00:10:45,508 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
00:11:00,613 INFO [UpdateChecker] Checking if a new version is available
00:11:05,523 INFO [LibraryUpdaterThread] Starting Library Updater Thread
00:11:05,943 INFO [LibraryUpdaterThread] Removing '10000AC' from Library
00:11:07,491 INFO [LibraryUpdaterThread] Removing 'A.Ciegas' from Library
00:11:08,884 INFO [LibraryUpdaterThread] Removing 'Agora' from Library
00:11:09,469 INFO [LibraryUpdaterThread] Removing 'Invictus' from Library
00:11:09,931 INFO [LibraryUpdaterThread] Removing 'Krabat y el molino del diablo' from Library
00:11:10,341 INFO [LibraryUpdaterThread] Removing 'La Cuarta Fase' from Library
00:11:10,732 INFO [LibraryUpdaterThread] Removing 'Star Trek' from Library
00:11:21,629 INFO [LibraryUpdaterThread] Added file 'dsc_0006.jpg' to Library
00:13:05,708 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
00:22:13,926 INFO [AbstractModel] Remote exception occured, removing the listener: CORBA COMM_FAILURE 1398079689 No; nested exception is:
org.omg.CORBA.COMM_FAILURE: vmcid: SUN minor code: 201 completed: No
00:22:13,926 INFO [WebServer] WebServer shutting down
00:22:13,927 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
00:22:13,930 INFO [EventDispatcher] Leaving EventDispatcher
00:22:13,930 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
00:22:13,931 INFO [DiscoverySearchListener] Leaving DiscoverySearchListener
00:22:13,931 INFO [DatabaseManager] Shutting down database
00:22:14,157 INFO [ORBServer] Stopped Corba server
Thank youu very much for your work! If you need other thing please tell me it.
jmdlp
Post Sun Apr 18, 2010 12:37 am
I'll need the detailed log (link is in my signature).
jmleon
Post Sun Apr 18, 2010 11:12 am
Soory zip, here is the detailed log:
12:45:48,279 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:45:48,279 DEBUG [ResourceTransportRequestHandler] Request for resource 75 and type 'COVER_IMAGE' received
12:45:48,279 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 75)
12:45:48,280 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 75
12:45:48,280 DEBUG [ResourceTransportRequestHandler] Sending file back
12:45:48,280 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 3370, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
12:45:48,287 DEBUG [WebServer] Incoming connection from /192.168.1.117:36044
12:45:48,287 DEBUG [ResourceTransportRequestHandler] GET /resource/76/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
12:45:48,287 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:45:48,287 DEBUG [ResourceTransportRequestHandler] Request for resource 76 and type 'COVER_IMAGE' received
12:45:48,287 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 76)
12:45:48,288 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 76
12:45:48,288 DEBUG [ResourceTransportRequestHandler] Sending file back
12:45:48,288 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 4705, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
12:45:53,428 DEBUG [WebServer] Incoming connection from /192.168.1.117:39003
12:45:53,428 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:45:53,432 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
12:45:53,432 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder 12
12:45:53,444 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 15
12:45:53,455 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 12
12:45:53,457 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:45:53,466 DEBUG [WebServer] Incoming connection from /192.168.1.117:38139
12:45:53,467 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:45:53,469 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
12:45:53,469 DEBUG [FolderDAOImpl] Reading a Folder (id = 12)
12:45:53,470 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 12
12:45:53,472 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:45:53,480 DEBUG [WebServer] Incoming connection from /192.168.1.117:44044
12:45:53,481 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:45:53,484 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
12:45:53,484 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder 12
12:45:53,484 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 15
12:45:53,485 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 12 (from=0, count=2147483647)
12:45:53,485 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 12
12:45:53,487 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:45:55,213 DEBUG [WebServer] Incoming connection from /192.168.1.117:38555
12:45:55,214 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:45:55,218 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12$F15, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
12:45:55,218 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder 15
12:45:55,226 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 16
12:45:55,236 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 15
12:45:55,238 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:45:55,246 DEBUG [WebServer] Incoming connection from /192.168.1.117:35914
12:45:55,246 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:45:55,250 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12$F15, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
12:45:55,250 DEBUG [FolderDAOImpl] Reading a Folder (id = 15)
12:45:55,250 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 15
12:45:55,253 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:45:55,262 DEBUG [WebServer] Incoming connection from /192.168.1.117:56168
12:45:55,263 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:45:55,280 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12$F15, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
12:45:55,280 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder 15
12:45:55,292 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 16
12:45:55,293 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 15 (from=0, count=2147483647)
12:45:55,293 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 15
12:45:55,296 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:45:56,533 DEBUG [WebServer] Incoming connection from /192.168.1.117:53412
12:45:56,533 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:45:56,537 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12$F15$F16, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
12:45:56,537 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder 16
12:45:56,545 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 16 (from=0, count=2147483647)
12:45:56,546 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
12:45:56,546 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 73
12:45:56,640 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 73
12:45:56,643 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 73
12:45:56,645 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 73)
12:45:56,645 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
12:45:56,645 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 74
12:45:56,728 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 74
12:45:56,730 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 74
12:45:56,733 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 74)
12:45:56,733 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 16
12:45:56,738 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:45:56,748 DEBUG [WebServer] Incoming connection from /192.168.1.117:34319
12:45:56,749 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:45:56,752 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12$F15$F16, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
12:45:56,752 DEBUG [FolderDAOImpl] Reading a Folder (id = 16)
12:45:56,752 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 16
12:45:56,755 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:45:56,767 DEBUG [WebServer] Incoming connection from /192.168.1.117:34485
12:45:56,768 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:45:56,770 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12$F15$F16, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
12:45:56,770 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder 16
12:45:56,771 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 16 (from=0, count=2147483647)
12:45:56,772 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
12:45:56,772 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 73
12:45:56,850 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 73
12:45:56,852 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 73
12:45:56,854 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 73)
12:45:56,855 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
12:45:56,855 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 74
12:45:56,934 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 74
12:45:56,937 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 74
12:45:56,939 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 74)
12:45:56,939 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 16
12:45:56,943 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:45:57,123 DEBUG [WebServer] Incoming connection from /192.168.1.117:36045
12:45:57,124 DEBUG [ResourceTransportRequestHandler] GET /resource/73/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
12:45:57,124 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:45:57,124 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'COVER_IMAGE' received
12:45:57,124 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 73)
12:45:57,125 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 73
12:45:57,125 DEBUG [ResourceTransportRequestHandler] Sending file back
12:45:57,125 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 4665, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
12:45:57,135 DEBUG [WebServer] Incoming connection from /192.168.1.117:36046
12:45:57,135 DEBUG [ResourceTransportRequestHandler] GET /resource/74/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
12:45:57,135 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:45:57,135 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'COVER_IMAGE' received
12:45:57,135 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 74)
12:45:57,136 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 74
12:45:57,136 DEBUG [ResourceTransportRequestHandler] Sending file back
12:45:57,136 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 6146, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
12:46:03,480 DEBUG [WebServer] Incoming connection from /192.168.1.117:42279
12:46:03,480 DEBUG [ResourceTransportRequestHandler] HEAD /resource/73/MEDIA_ITEM/AVI HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, Host: 192.168.1.2:8895, ]
12:46:03,480 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:03,480 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'MEDIA_ITEM' received
12:46:03,480 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:03,488 DEBUG [VideoDAOImpl] Reading a Video (id = 73)
12:46:03,495 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x11.avi in its original format
12:46:03,495 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:03,496 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
12:46:03,496 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 367411578, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:03,505 DEBUG [WebServer] Incoming connection from /192.168.1.117:43889
12:46:03,505 DEBUG [ResourceTransportRequestHandler] GET /resource/73/MEDIA_ITEM/AVI HTTP/1.0, headers = [Range: bytes=0-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, getMediaInfo.sec: 1, Host: 192.168.1.2:8895, ]
12:46:03,505 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:03,505 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'MEDIA_ITEM' received
12:46:03,505 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:03,505 DEBUG [VideoDAOImpl] Reading a Video (id = 73)
12:46:03,506 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x11.avi in its original format
12:46:03,506 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:03,506 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:03,506 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 0-367411577/367411578, Content-Length: 367411578, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:03,600 DEBUG [WebServer] I/O error: Broken pipe
12:46:03,623 DEBUG [WebServer] Incoming connection from /192.168.1.117:53048
12:46:03,624 DEBUG [ResourceTransportRequestHandler] GET /resource/73/MEDIA_ITEM/AVI HTTP/1.0, headers = [Range: bytes=364756690-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.2:8895, ]
12:46:03,624 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:03,624 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'MEDIA_ITEM' received
12:46:03,624 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:03,624 DEBUG [VideoDAOImpl] Reading a Video (id = 73)
12:46:03,625 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x11.avi in its original format
12:46:03,625 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:03,625 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:03,625 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 364756690-367411577/367411578, Content-Length: 2654888, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:05,541 DEBUG [WebServer] Incoming connection from /192.168.1.117:34178
12:46:05,541 DEBUG [ResourceTransportRequestHandler] GET /resource/73/MEDIA_ITEM/AVI HTTP/1.0, headers = [Range: bytes=2048-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.2:8895, ]
12:46:05,541 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:05,541 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'MEDIA_ITEM' received
12:46:05,541 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:05,542 DEBUG [VideoDAOImpl] Reading a Video (id = 73)
12:46:05,542 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x11.avi in its original format
12:46:05,542 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:05,542 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:05,543 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 2048-367411577/367411578, Content-Length: 367409530, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:05,552 DEBUG [WebServer] I/O error: Broken pipe
12:46:05,558 DEBUG [WebServer] Incoming connection from /192.168.1.117:60833
12:46:05,559 DEBUG [ResourceTransportRequestHandler] GET /resource/73/MEDIA_ITEM/AVI HTTP/1.0, headers = [Range: bytes=2052-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.2:8895, ]
12:46:05,559 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:05,559 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'MEDIA_ITEM' received
12:46:05,559 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:05,559 DEBUG [VideoDAOImpl] Reading a Video (id = 73)
12:46:05,559 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x11.avi in its original format
12:46:05,559 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:05,560 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:05,560 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 2052-367411577/367411578, Content-Length: 367409526, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:05,606 DEBUG [WebServer] I/O error: Broken pipe
12:46:05,625 DEBUG [WebServer] Incoming connection from /192.168.1.117:58690
12:46:05,625 DEBUG [ResourceTransportRequestHandler] GET /resource/73/MEDIA_ITEM/AVI HTTP/1.0, headers = [Range: bytes=2048-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.2:8895, ]
12:46:05,625 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:05,625 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'MEDIA_ITEM' received
12:46:05,625 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:05,625 DEBUG [VideoDAOImpl] Reading a Video (id = 73)
12:46:05,625 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x11.avi in its original format
12:46:05,625 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:05,626 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:05,626 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 2048-367411577/367411578, Content-Length: 367409530, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:05,800 DEBUG [WebServer] Incoming connection from /192.168.1.117:45653
12:46:05,810 DEBUG [ResourceTransportRequestHandler] HEAD /resource/73/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
12:46:05,810 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:05,811 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'MEDIA_ITEM' received
12:46:05,811 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:05,811 DEBUG [VideoDAOImpl] Reading a Video (id = 73)
12:46:05,812 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x11.avi in its original format
12:46:05,812 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:05,816 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:05,816 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:05,816 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
12:46:05,816 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 367411578, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, transferMode.dlna.org: Streaming, CaptionInfo.sec: http://192.168.1.2:8895/resource/73/SUBTITLE, ]
12:46:05,821 DEBUG [WebServer] Incoming connection from /192.168.1.117:52794
12:46:05,821 DEBUG [ResourceTransportRequestHandler] HEAD /resource/73/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
12:46:05,821 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:05,821 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'MEDIA_ITEM' received
12:46:05,821 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:05,822 DEBUG [VideoDAOImpl] Reading a Video (id = 73)
12:46:05,822 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x11.avi in its original format
12:46:05,822 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:05,824 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:05,824 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:05,825 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
12:46:05,825 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 367411578, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, transferMode.dlna.org: Streaming, CaptionInfo.sec: http://192.168.1.2:8895/resource/73/SUBTITLE, ]
12:46:05,829 DEBUG [WebServer] Incoming connection from /192.168.1.117:36047
12:46:05,829 DEBUG [ResourceTransportRequestHandler] GET /resource/73/SUBTITLE HTTP/1.0, headers = [HOST: 192.168.1.2:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Background, ]
12:46:05,829 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:05,829 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'SUBTITLE' received
12:46:05,830 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:05,831 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:05,831 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 73
12:46:05,867 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:05,867 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: smi/caption, Content-Length: 36123, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, transferMode.dlna.org: Streaming, ]
12:46:41,134 DEBUG [WebServer] Incoming connection from /192.168.1.117:55677
12:46:41,134 DEBUG [ResourceTransportRequestHandler] HEAD /resource/73/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
12:46:41,134 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:41,134 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'MEDIA_ITEM' received
12:46:41,134 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:41,135 DEBUG [VideoDAOImpl] Reading a Video (id = 73)
12:46:41,135 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x11.avi in its original format
12:46:41,135 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:41,136 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:41,136 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:41,137 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
12:46:41,137 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 367411578, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, transferMode.dlna.org: Streaming, CaptionInfo.sec: http://192.168.1.2:8895/resource/73/SUBTITLE, ]
12:46:41,144 DEBUG [WebServer] Incoming connection from /192.168.1.117:38013
12:46:41,144 DEBUG [ResourceTransportRequestHandler] HEAD /resource/73/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
12:46:41,144 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:41,144 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'MEDIA_ITEM' received
12:46:41,144 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:41,144 DEBUG [VideoDAOImpl] Reading a Video (id = 73)
12:46:41,145 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x11.avi in its original format
12:46:41,145 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:41,145 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:41,146 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
12:46:41,146 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 367411578, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, transferMode.dlna.org: Streaming, CaptionInfo.sec: http://192.168.1.2:8895/resource/73/SUBTITLE, ]
12:46:41,153 DEBUG [WebServer] Incoming connection from /192.168.1.117:36048
12:46:41,154 DEBUG [ResourceTransportRequestHandler] GET /resource/73/SUBTITLE HTTP/1.0, headers = [HOST: 192.168.1.2:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Background, ]
12:46:41,154 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:41,154 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'SUBTITLE' received
12:46:41,154 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 73)
12:46:41,155 DEBUG [MediaItemDAOImpl] Getting file of media item 73
12:46:41,155 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 73
12:46:41,156 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:41,156 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: smi/caption, Content-Length: 36123, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, transferMode.dlna.org: Streaming, ]
12:46:41,187 DEBUG [WebServer] Incoming connection from /192.168.1.117:37293
12:46:41,188 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_SetBookmark"' from DLNADOC/1.50:
12:46:41,198 DEBUG [ServiceControlRequestHandler] Returning error SOAP message
12:46:41,206 DEBUG [WebServer] Incoming connection from /192.168.1.117:57059
12:46:41,208 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:46:41,211 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12$F15$F16, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 1, sortCriteria =
12:46:41,211 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder 16
12:46:41,212 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 16 (from=0, count=2147483647)
12:46:41,213 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
12:46:41,213 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 73
12:46:41,296 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 73
12:46:41,298 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 73
12:46:41,301 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 73)
12:46:41,301 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
12:46:41,301 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 74
12:46:41,380 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 74
12:46:41,382 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 74
12:46:41,385 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 74)
12:46:41,385 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 16
12:46:41,388 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:46:42,269 DEBUG [WebServer] I/O error: Broken pipe
12:46:42,926 DEBUG [WebServer] Incoming connection from /192.168.1.117:51085
12:46:42,927 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:46:42,931 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12$F15$F16, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 1, sortCriteria =
12:46:42,931 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder 16
12:46:42,932 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 16 (from=0, count=2147483647)
12:46:42,933 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
12:46:42,933 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 73
12:46:43,015 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 73
12:46:43,018 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 73
12:46:43,020 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 73)
12:46:43,020 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
12:46:43,021 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 74
12:46:43,100 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 74
12:46:43,103 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 74
12:46:43,105 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 74)
12:46:43,105 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 16
12:46:43,108 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:46:43,134 DEBUG [WebServer] Incoming connection from /192.168.1.117:36049
12:46:43,135 DEBUG [ResourceTransportRequestHandler] GET /resource/73/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
12:46:43,135 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:43,135 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'COVER_IMAGE' received
12:46:43,135 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 73)
12:46:43,136 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 73
12:46:43,136 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:43,136 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 4665, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
12:46:43,148 DEBUG [WebServer] Incoming connection from /192.168.1.117:36050
12:46:43,148 DEBUG [ResourceTransportRequestHandler] GET /resource/74/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
12:46:43,148 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:43,148 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'COVER_IMAGE' received
12:46:43,148 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 74)
12:46:43,148 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 74
12:46:43,149 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:43,149 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 6146, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
12:46:45,888 DEBUG [WebServer] Incoming connection from /192.168.1.117:47198
12:46:45,889 DEBUG [ResourceTransportRequestHandler] HEAD /resource/74/MEDIA_ITEM/AVI HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, Host: 192.168.1.2:8895, ]
12:46:45,889 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:45,889 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'MEDIA_ITEM' received
12:46:45,889 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:46:45,889 DEBUG [VideoDAOImpl] Reading a Video (id = 74)
12:46:45,890 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x12.avi in its original format
12:46:45,890 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:46:45,892 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
12:46:45,892 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 367186416, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:45,900 DEBUG [WebServer] Incoming connection from /192.168.1.117:56641
12:46:45,900 DEBUG [ResourceTransportRequestHandler] GET /resource/74/MEDIA_ITEM/AVI HTTP/1.0, headers = [Range: bytes=0-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, getMediaInfo.sec: 1, Host: 192.168.1.2:8895, ]
12:46:45,900 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:45,900 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'MEDIA_ITEM' received
12:46:45,900 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:46:45,901 DEBUG [VideoDAOImpl] Reading a Video (id = 74)
12:46:45,901 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x12.avi in its original format
12:46:45,901 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:46:45,901 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:45,901 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 0-367186415/367186416, Content-Length: 367186416, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:45,950 DEBUG [WebServer] I/O error: Broken pipe
12:46:45,968 DEBUG [WebServer] Incoming connection from /192.168.1.117:42485
12:46:45,969 DEBUG [ResourceTransportRequestHandler] GET /resource/74/MEDIA_ITEM/AVI HTTP/1.0, headers = [Range: bytes=364547752-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.2:8895, ]
12:46:45,969 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:45,969 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'MEDIA_ITEM' received
12:46:45,969 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:46:45,969 DEBUG [VideoDAOImpl] Reading a Video (id = 74)
12:46:45,969 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x12.avi in its original format
12:46:45,969 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:46:45,970 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:45,970 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 364547752-367186415/367186416, Content-Length: 2638664, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:47,859 DEBUG [WebServer] Incoming connection from /192.168.1.117:43604
12:46:47,859 DEBUG [ResourceTransportRequestHandler] GET /resource/74/MEDIA_ITEM/AVI HTTP/1.0, headers = [Range: bytes=4108-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.2:8895, ]
12:46:47,860 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:47,860 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'MEDIA_ITEM' received
12:46:47,860 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:46:47,860 DEBUG [VideoDAOImpl] Reading a Video (id = 74)
12:46:47,861 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x12.avi in its original format
12:46:47,861 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:46:47,861 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:47,861 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 4108-367186415/367186416, Content-Length: 367182308, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:47,871 DEBUG [WebServer] I/O error: Broken pipe
12:46:47,881 DEBUG [WebServer] Incoming connection from /192.168.1.117:52855
12:46:47,881 DEBUG [ResourceTransportRequestHandler] GET /resource/74/MEDIA_ITEM/AVI HTTP/1.0, headers = [Range: bytes=12344-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.2:8895, ]
12:46:47,881 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:47,881 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'MEDIA_ITEM' received
12:46:47,881 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:46:47,881 DEBUG [VideoDAOImpl] Reading a Video (id = 74)
12:46:47,882 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x12.avi in its original format
12:46:47,882 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:46:47,882 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:47,882 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 12344-367186415/367186416, Content-Length: 367174072, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:47,926 DEBUG [WebServer] I/O error: Broken pipe
12:46:47,932 DEBUG [WebServer] Incoming connection from /192.168.1.117:36549
12:46:47,933 DEBUG [ResourceTransportRequestHandler] GET /resource/74/MEDIA_ITEM/AVI HTTP/1.0, headers = [Range: bytes=4112-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.2:8895, ]
12:46:47,933 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:47,933 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'MEDIA_ITEM' received
12:46:47,933 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:46:47,933 DEBUG [VideoDAOImpl] Reading a Video (id = 74)
12:46:47,934 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x12.avi in its original format
12:46:47,934 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:46:47,934 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:47,934 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 4112-367186415/367186416, Content-Length: 367182304, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:47,968 DEBUG [WebServer] I/O error: Broken pipe
12:46:47,988 DEBUG [WebServer] Incoming connection from /192.168.1.117:32878
12:46:47,989 DEBUG [ResourceTransportRequestHandler] GET /resource/74/MEDIA_ITEM/AVI HTTP/1.0, headers = [Range: bytes=4108-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.2:8895, ]
12:46:47,989 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:47,989 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'MEDIA_ITEM' received
12:46:47,989 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:46:47,989 DEBUG [VideoDAOImpl] Reading a Video (id = 74)
12:46:47,989 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x12.avi in its original format
12:46:47,989 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:46:47,990 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:47,990 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 4108-367186415/367186416, Content-Length: 367182308, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
12:46:48,129 DEBUG [WebServer] Incoming connection from /192.168.1.117:37336
12:46:48,129 DEBUG [ResourceTransportRequestHandler] HEAD /resource/74/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
12:46:48,129 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:48,129 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'MEDIA_ITEM' received
12:46:48,129 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:46:48,130 DEBUG [VideoDAOImpl] Reading a Video (id = 74)
12:46:48,130 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x12.avi in its original format
12:46:48,130 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:46:48,131 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:46:48,131 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:46:48,132 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
12:46:48,132 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 367186416, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, transferMode.dlna.org: Streaming, CaptionInfo.sec: http://192.168.1.2:8895/resource/74/SUBTITLE, ]
12:46:48,142 DEBUG [WebServer] Incoming connection from /192.168.1.117:56518
12:46:48,142 DEBUG [ResourceTransportRequestHandler] HEAD /resource/74/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
12:46:48,142 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:48,142 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'MEDIA_ITEM' received
12:46:48,142 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:46:48,142 DEBUG [VideoDAOImpl] Reading a Video (id = 74)
12:46:48,143 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x12.avi in its original format
12:46:48,143 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:46:48,143 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:46:48,144 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
12:46:48,144 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 367186416, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, transferMode.dlna.org: Streaming, CaptionInfo.sec: http://192.168.1.2:8895/resource/74/SUBTITLE, ]
12:46:48,150 DEBUG [WebServer] Incoming connection from /192.168.1.117:36051
12:46:48,150 DEBUG [ResourceTransportRequestHandler] GET /resource/74/SUBTITLE HTTP/1.0, headers = [HOST: 192.168.1.2:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Background, ]
12:46:48,150 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:46:48,150 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'SUBTITLE' received
12:46:48,150 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:46:48,150 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:46:48,151 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 74
12:46:48,161 DEBUG [ResourceTransportRequestHandler] Sending file back
12:46:48,161 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: smi/caption, Content-Length: 44812, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, transferMode.dlna.org: Streaming, ]
12:47:21,049 DEBUG [WebServer] Incoming connection from /192.168.1.117:60359
12:47:21,049 DEBUG [ResourceTransportRequestHandler] HEAD /resource/74/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
12:47:21,049 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:47:21,050 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'MEDIA_ITEM' received
12:47:21,050 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:47:21,050 DEBUG [VideoDAOImpl] Reading a Video (id = 74)
12:47:21,051 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x12.avi in its original format
12:47:21,051 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:47:21,051 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:47:21,052 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:47:21,052 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
12:47:21,052 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 367186416, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, transferMode.dlna.org: Streaming, CaptionInfo.sec: http://192.168.1.2:8895/resource/74/SUBTITLE, ]
12:47:21,057 DEBUG [WebServer] Incoming connection from /192.168.1.117:59495
12:47:21,058 DEBUG [ResourceTransportRequestHandler] HEAD /resource/74/MEDIA_ITEM/AVI HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
12:47:21,058 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:47:21,058 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'MEDIA_ITEM' received
12:47:21,058 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:47:21,058 DEBUG [VideoDAOImpl] Reading a Video (id = 74)
12:47:21,059 DEBUG [MediaResourceRetrievalStrategy] Delivering file Lost 6x12.avi in its original format
12:47:21,059 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:47:21,059 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:47:21,060 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
12:47:21,060 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-msvideo, Content-Length: 367186416, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, transferMode.dlna.org: Streaming, CaptionInfo.sec: http://192.168.1.2:8895/resource/74/SUBTITLE, ]
12:47:21,069 DEBUG [WebServer] Incoming connection from /192.168.1.117:36052
12:47:21,069 DEBUG [ResourceTransportRequestHandler] GET /resource/74/SUBTITLE HTTP/1.0, headers = [HOST: 192.168.1.2:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Background, ]
12:47:21,070 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:47:21,070 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'SUBTITLE' received
12:47:21,070 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 74)
12:47:21,070 DEBUG [MediaItemDAOImpl] Getting file of media item 74
12:47:21,071 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 74
12:47:21,071 DEBUG [ResourceTransportRequestHandler] Sending file back
12:47:21,071 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: smi/caption, Content-Length: 44812, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, transferMode.dlna.org: Streaming, ]
12:47:21,113 DEBUG [WebServer] Incoming connection from /192.168.1.117:59666
12:47:21,114 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_SetBookmark"' from DLNADOC/1.50:
12:47:21,117 DEBUG [ServiceControlRequestHandler] Returning error SOAP message
12:47:21,124 DEBUG [WebServer] Incoming connection from /192.168.1.117:40557
12:47:21,124 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:47:21,127 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12$F15$F16, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 1, sortCriteria =
12:47:21,127 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder 16
12:47:21,128 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 16 (from=0, count=2147483647)
12:47:21,128 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
12:47:21,129 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 73
12:47:21,207 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 73
12:47:21,210 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 73
12:47:21,212 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 73)
12:47:21,213 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
12:47:21,213 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 74
12:47:21,293 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 74
12:47:21,296 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 74
12:47:21,298 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 74)
12:47:21,298 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 16
12:47:21,302 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:47:22,180 DEBUG [WebServer] I/O error: Broken pipe
12:47:22,813 DEBUG [WebServer] Incoming connection from /192.168.1.117:39415
12:47:22,816 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
12:47:22,819 DEBUG [ContentDirectory] Browse() called for profile Samsung WiselinkPro with parameters: objectID = V_F#FOL_R6$F12$F15$F16, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 1, sortCriteria =
12:47:22,820 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder 16
12:47:22,820 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 16 (from=0, count=2147483647)
12:47:22,821 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
12:47:22,821 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 73
12:47:22,902 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 73
12:47:22,904 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 73
12:47:22,907 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 73)
12:47:22,907 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
12:47:22,907 DEBUG [PersonDAOImpl] Retrieving list of persons with role ACTOR for MediaItem 74
12:47:22,991 DEBUG [PersonDAOImpl] Retrieving list of persons with role DIRECTOR for MediaItem 74
12:47:22,993 DEBUG [PersonDAOImpl] Retrieving list of persons with role PRODUCER for MediaItem 74
12:47:22,996 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 74)
12:47:22,996 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 16
12:47:22,999 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
12:47:23,033 DEBUG [WebServer] Incoming connection from /192.168.1.117:36053
12:47:23,034 DEBUG [ResourceTransportRequestHandler] GET /resource/73/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
12:47:23,034 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:47:23,034 DEBUG [ResourceTransportRequestHandler] Request for resource 73 and type 'COVER_IMAGE' received
12:47:23,034 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 73)
12:47:23,035 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 73
12:47:23,035 DEBUG [ResourceTransportRequestHandler] Sending file back
12:47:23,035 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 4665, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
12:47:23,051 DEBUG [WebServer] Incoming connection from /192.168.1.117:36054
12:47:23,051 DEBUG [ResourceTransportRequestHandler] GET /resource/74/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
12:47:23,052 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using renderer profile 'Samsung WiselinkPro'
12:47:23,052 DEBUG [ResourceTransportRequestHandler] Request for resource 74 and type 'COVER_IMAGE' received
12:47:23,052 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 74)
12:47:23,052 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 74
12:47:23,052 DEBUG [ResourceTransportRequestHandler] Sending file back
12:47:23,052 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Content-Length: 6146, Cache-control: no-cache, Pragma: no-cache, Server: Mac OS X UPnP/1.0 Serviio 0.3.1, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
12:54:54,816 INFO [AbstractModel] Remote exception occured, removing the listener: CORBA COMM_FAILURE 1398079696 Maybe; nested exception is:
org.omg.CORBA.COMM_FAILURE: vmcid: SUN minor code: 208 completed: Maybe
12:54:54,816 DEBUG [WebServer] Socket closed
12:54:54,816 DEBUG [DiscoveryManager] UPNP device 83403509-60a4-3ac0-bae1-94340baf2344 is unavailable
Thank you!
Post Sun Apr 18, 2010 12:04 pm
Re: Subtitles support
HI, thanks. So the subtitle file is found and Serviio sends it back. I can see these possible scenarios going on:
1) Samsung changed the way how they expect the subtitle file to be sent in the C-series TVs. For this I'd need you to sniff the HTTP packets etc.
2) The srt file is 'corrupted'. I have had some SRT files that the TV didn't like. Did you try other shows? Is the subtitle displayed when you use Samsung's server?
3) This is tretching it, but I guess you turned subtitles display on on the TV ;-)
jmleon
Post Sun Apr 18, 2010 12:35 pm
ok, we go on..
1)Can I give you some aditional information at this point?
2)Remember I put avi and srt files in a usb pen and TV play everythig ok: movie with subtitles. however I post some of srt subtitle down, so you can see the format...
3)Yes I turned on subtitles in TV :-)
1
00:00:09,512 --> 00:00:13,139
Señor Hume ... Mi nombre es Zoe..
2
00:00:13,981 --> 00:00:17,964
Se que esta desorientado.
Ha estado inconsciente durante 3 dias.
3
00:00:18,520 --> 00:00:20,599
Pero ahora esta sedado
por via intravenosa
4
00:00:20,600 --> 00:00:23,408
y le acabo de inyectar algo
para ayudarlo a levantarse.
Than you!
Post Sun Apr 18, 2010 12:52 pm
Isee you are on a Mac. Any chance you could try the Samsung PC Share manager on a Windows box?
Return to Feature requests
Users browsing this forum: Google [Bot] and 21 guests
