fast forward/rewind
delly47
Post Thu Apr 14, 2011 11:50 pm
fast forward/rewind
Is fast forward/Rewind supported for samsung tvs?
Post Fri Apr 15, 2011 9:54 am
Re: fast forward/rewind
yes just use the < and > arrow keys :)
it only skips forward 20 second chunks on C series but that is a limitation of the device and not serviio.
the B series seems to handle it slightly better from what im told and if you hold the arrow key it jumps forward long duration the longer u hold the key.
i have no info on the D series but as far as i know it acts like the C series and only jump forward in 20 second chunks.
Troutking
Post Fri Apr 15, 2011 10:47 am
There is a massive difference between C6000 and C8000 series, C6000 series doing a better ff/rw job...
TV: Samsung UE40C8705
FW: T-VALDEUC-3007.1
Post Fri Apr 15, 2011 12:22 pm
Yes the D5300 jumps 20 second intervals, but if you hold the button too long it stops and just plays normally. I can get about 4-5 mins of movie FF before it starts playing while holding the button down.
Tarkin
Post Tue Apr 26, 2011 11:12 am
Hmmm...Not sure about this, does not work on most of my movies on my B Series.
Post Tue Apr 26, 2011 4:00 pm
i did say slightly but i dont own one so its only taken from people who do liek ZIP..
Post Tue Apr 26, 2011 4:38 pm
Depends on file type, the TV doesn't support it for all file types.
RamKat
Post Sat Apr 30, 2011 9:56 am
What I am finding on the C5500 is that it would initially fast forward well but as the watching point moves futher into the file it would become gradually slower to react untill it is about impossible to forward at about the 30 min mark.
Post Sat Apr 30, 2011 12:29 pm
RamKat wrote:What I am finding on the C5500 is that it would initially fast forward well but as the watching point moves futher into the file it would become gradually slower to react untill it is about impossible to forward at about the 30 min mark.
hmm thats odd your first person to say that, for most it either work or it doesnt depending on what firmware they have installed. What is your current firmware version ?
delly47
Post Sun May 01, 2011 12:34 am
ff and rw works with videos through usb
delly47
Post Sun May 01, 2011 12:42 am
also thanks for making such a great media server!
sunchar
Post Sat May 21, 2011 4:52 am
As Zip said, it depends of file format. Using AVI, MKV or something similar rew and fwd works, but if you use another format as FLV won't work. I'm not sure, but I think this is a device limitation, not serviio limitation.
carbone
Post Sun Jun 12, 2011 10:28 pm
I have a Samsung D8000 and I can't fast forward/rewind any .mkv files. Is anyone able to do this with this TV or other file formats?
