Samsung C7700 in-movie skip
Karuko
Post Mon Jan 24, 2011 10:48 am
Noticed that two mkv movies where serviio would reach a determined place (it always happens on the same place) and skip to the next file. I'm not sure if the problem is with the file or the server (still have to try the file directly on the TV). I tried to see the problem and couldn't see anything in the log. This has been the only problem Serviio has had with the TV, all the other features that are available and work great.
I am currently away from this TV for the next few weeks, so I won't be able to give you the log. But do you have any idea why this could be happening? Has anyone else had a similar experience?
Karuko
Post Sat Apr 16, 2011 9:17 am
Re: Samsung C7700 in-movie skip
I've been able to test this again with the new Serviio 0.5.2 on a C7700 and still get an in-movie skip.
Here is the info on the file. Anything else needed?
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[matroska,webm @ 0128bbc0] max_analyze_duration reached
[matroska,webm @ 0128bbc0] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from 'F:\HD\Oceanos de fuego.mkv':
    title           : Oceanos de fuego.mkv
  Duration: 02:16:24.96, start: 0.000000, bitrate: 2816 kb/s
    Stream #0.0: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.98 fps,
23.98 tbr, 1k tbn, 47.95 tbc
    Stream #0.1(spa): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
    Stream #0.2(spa): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
    Stream #0.3(eng): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
    Stream #0.4(spa): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.5(eng): Subtitle: [0][0][0][0] / 0x0000
Post Sat Apr 16, 2011 10:10 am
RE: Samsung C7700 in-movie skip
Does it happen with Samsungs server too?
Karuko
Post Sun Apr 17, 2011 8:57 am
Yes, the same thing happens with the Samsung software, although I was able to see a warning message this time saying that the codec was not compatible... can a file change codec midway through the movie? I'm starting to think the problem could be with the file. Is there a way to recode it fully to a standard codec?
Post Sun Apr 17, 2011 12:00 pm
Yes, the problem is the file - or it has been encoded in a way the TV doesn't like. You could use some tool to re-encode it manually. Might also look here if you find something useful: viewforum.php?f=17
