profiles list and other questions
Dejavu
Post Sun Apr 17, 2011 12:48 pm
I've just bought a Sony Bravia KDL-32EX500 (I suppose it'd fall into the 2011 series)
Looking for a DLNA server, I ran across Serviio and it seems to make quite a good job at serving/transcoding files. Thanks for that !
I have a few noob questions that someone could help me with :
1) First of all, it seems most of the work serviio does heavily relies on a profile tailored for the specific display renderer... Is there a place on the site gathering all (up to date) profiles for a specific tv set ?
2) I've tried using serviio over wifi with a divx, the video was all stuttering. My renderer can play divx natively, as I was able to confirm from a fat32 usb drive... Is it because of a transcoding issue, or is it more likely that the wifi is too slow for streaming in any case ?
3) When playing divx with serviio through rj45 cable, I managed to have the .srt subtitles working, but for some files the option to activate them was not there, even though there was a .srt file with same name as the .avi file... Ideas ?
4) I'm running serviio on a windows7 box, and it seems the shortcuts to start/stop the service don't work effectively. I end up running services.msc and starting/stopping it manually. Any idea on the matter ?
And last but not least :
5) I didn't manage to play any 1080p file yet ! Quite sad for a brand new fullhd set :-/ I get the sound but no video. Any clue on how to fix that ? (Answer might be related to question 1...)
Thanks for any help
Edit: also, I don't really understand why there is a profile for the pc server in the serviio console... Isn't it just the display renderer that needs to get assigned a profile ?
Edit: while I'm posting, it might be of interest to note that I had to edit the firewall to open TCP 8895 and UDP 1900 ports. The installer inserted a few lines about serviio but did not open those, and it wasn't working until I did...
Dejavu
Post Sun Apr 17, 2011 2:24 pm
Re: profiles list and other questions
Dejavu wrote:4) I'm running serviio on a windows7 box, and it seems the shortcuts to start/stop the service don't work effectively. I end up running services.msc and starting/stopping it manually. Any idea on the matter ?
This one is solved, it was UAC kicking in and silently preventing the action.
I tried to make a batch file to handle this case and at least warn the user, but really I miss too many basics in this language to do so.
If I eventually gather enough informaiton to make the command window stick in case the action fails, I'll post it.
Dejavu
Post Sun Apr 17, 2011 2:50 pm
Dejavu wrote:1) First of all, it seems most of the work serviio does heavily relies on a profile tailored for the specific display renderer... Is there a place on the site gathering all (up to date) profiles for a specific tv set ?
Sorry I didn't notice before that a forum section is dedicated to this, but what is in there looks more like another help topic than a profile sharing area :/
Post Sun Apr 17, 2011 3:57 pm
All latest profiles are bundled with Serviio. On the forum you can find tweaks that work better/differently for individual users.
Dejavu
Post Sun Apr 17, 2011 6:19 pm
Right, but from what I gather the profile need to be specific for a given display renderer (and even depends on the year it was released). For example, with the app comes a "Sony Bravia TV" profile, when all Bravia TV don't behave the same, and 2011 versions don't behave the same as 2010 versions. I assume anyone with the same tv from the same year will be able to use the same profile, so I was thinking about some kind of profile database, where we could grab/push/update the best profile for a specific set.
Anyway, my main concern is on being able to play 1080p mkv files and the other questions...
Any tip would be appreciated.
Post Sun Apr 17, 2011 6:23 pm
Well you should ask in the Sony section. For 2011 models, there is discussion going on here: viewtopic.php?f=11&t=2079
Answers to your other questions (e.g. subtitles) can be here: viewtopic.php?f=11&t=425
Post Mon Apr 18, 2011 10:08 am
Dejavu wrote:Hi,
Sony Bravia KDL-32EX500 is a 2010 model series : Read the first post of this topic : viewtopic.php?f=11&t=425
I move your post into Sony section, so know you could post your question, we will try to answer you...
Dejavu
Post Mon Apr 18, 2011 7:48 pm
Illico wrote:
Dejavu wrote:Hi,
How come I don't see divx/xvid format in the "supported format" for Sony Bravia 2010 series ? xvid plays fine from an usb drive !
Anyhow, I wish I could test a 1024p movie on my screen. Right now using serviio I get sound but no video. Any clue about that ?
Post Mon Apr 18, 2011 7:52 pm
Dejavu wrote:How come I don't see divx/xvid format in the "supported format" for Sony Bravia 2010 series ? xvid plays fine from an usb drive !
Exactly it may work from USB but its NOT supported over DLNA.
Post Mon Apr 18, 2011 8:08 pm
Not supported over DLNA.
Dejavu wrote:Anyhow, I wish I could test a 1024p movie on my screen. Right now using serviio I get sound but no video. Any clue about that ?
1024p?? what this?
You mean 1920x1080 24p ?
Could you post "ffmpeg -i" result of this video ?
Dejavu
Post Mon Apr 18, 2011 8:31 pm
1024p?? what this?
I meant 1080p
here's the output :
FFmpeg version git-N-29157-gc967860, Copyright (c) 2000-2011 the FFmpeg developers
built on Apr 17 2011 13:48:41 with gcc 4.5.2
configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --enable-memalign-hack --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb
--enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enabl
e-libx264 --enable-libxavs --enable-libxvid --enable-zlib --cross-prefix=x86_64-w64-mingw32- --target-os=mingw32 --arch=x86_64 --extra-cflags=-I/home/kyle/software/ffmpeg/external-libraries/win64/incl
ude --extra-ldflags=-L/home/kyle/software/ffmpeg/external-libraries/win64/lib --pkg-config=pkg-config
libavutil 50. 40. 1 / 50. 40. 1
libavcodec 52.119. 1 / 52.119. 1
libavformat 52.108. 0 / 52.108. 0
libavdevice 52. 4. 0 / 52. 4. 0
libavfilter 1. 79. 0 / 1. 79. 0
libswscale 0. 13. 0 / 0. 13. 0
[matroska,webm @ 0000000001AAA2C0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (20000000/417083) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'twiz-greenhornet1080p-rpk-sample.mkv':
Duration: 00:00:46.01, start: 0.000000, bitrate: 1536 kb/s
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x800 [PAR 1:1 DAR 12:5], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
title : twiz-greenhornet1080p
Stream #0.1(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s (default)
Dejavu
Post Mon Apr 18, 2011 8:36 pm
I managed to find another sample, which works fine.
The only difference in ffmpg output is DAR 16:9 instead of DAR 12:5.
I suppose that sample was not real 1080p after all... But that doesn't explain why it doesn't play.
Also, if someone could tell me wheter the server profile has any meaning or not that would be nice. I assume only the profile associated with the display renderer is used, and that the server one is here just because we're in beta stages, but I'd like confirmation. At the moment I change both at once for each test...
Post Mon Apr 18, 2011 11:19 pm
Can you post mediainfo result for a file the file that doesn't play?
Dejavu
Post Mon Apr 18, 2011 11:30 pm
zip wrote:Can you post mediainfo result for a file the file that doesn't play?
I guess that would be that :
Unique ID : 233818367091776063033466048785646459964 (0xAFE7C78B8A84030AB255920D59B99C3C)
Complete name : X:\_films\test\twiz-greenhornet1080p-rpk-sample.mkv
Format : Matroska
File size : 43.3 MiB
Duration : 46s 13ms
Overall bit rate : 7 891 Kbps
Encoded date : UTC 2011-04-02 18:29:17
Writing application : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 46s 4ms
Bit rate : 6 225 Kbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.169
Stream size : 34.1 MiB (79%)
Title : twiz-greenhornet1080p
Language : English
Format : DTS
Codec ID : A_DTS
Duration : 46s 13ms
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Delay relative to video : 7ms
Stream size : 8.28 MiB (19%)
Language : English
Post Tue Apr 19, 2011 7:23 am
Dejavu wrote:I guess that would be that :
It looks good for me...no idea.
If you want to test a HD video on your TV, check these samples files: http://www.demo-world.eu/trailers/high- ... ailers.php
Dejavu
Post Tue Apr 19, 2011 10:30 am
I downloaded a sample from your link, and it worked fine.
The file that doesn't show video is still not working, but I had other files working fine, even over wifi... I guess there's something wrong with this specific file.
Users browsing this forum: Baidu [Spider] and 5 guests
