Subtitles not playing on Sharp TV
tuhsheen
Post Sun Jul 19, 2020 3:57 pm
Hello
Recently I got a new Sharp aquos tv as gift (must add it's most likely a budget one, as it's not running android tv).
I'm having problems running SRT files. They are not showing on TV through DLNA, but they do work through USB. This makes me think it's a profile problem.
Default profile detected by Serviio is the generic dlna profile. I shall add the Sharp Aquos profile gives an error.
All my subtitles were working perfect on my 10 year old samsung smart tv running the samsung E/F series profile.
Things I've tried and checked:
-Ran subtitles thourgh SRTwiz , didnt help.
-Subtitles are correctly named.
-Saved subtitles as UTF8.
-Tried loads of different profiles with no avail.
-Embedded subtitles also dont work (muxed with mkvtoolnix).
What does work is using burned-in subtitles.. But I'm really not a fan so I really hope there's a different solution.
Thanks in advance for any help.
Log from when I was trying different things.
(444.65 KiB) Downloaded 637 times
Post Sun Jul 19, 2020 8:59 pm
Re: Subtitles not playing on Sharp TV
What is most likely happening is that USB and DLNA support differs on the TV. That actually happens quite often, in that something will work from a USB drive but not via DLNA. Sometimes it's the codec, sometimes the container, and sometimes it's the captions. My Sharp TV uses the Roku OS, so not a direct comparison.
trafo
Post Mon Jul 20, 2020 2:36 am
tuhsheen wrote:Hello
I assume you tried "Enable extraction of text-based subtitles embedded in video files"? Beyond that, if you're on Windows, try the native Windows Media Streaming function with the mkv files embedded with subtitles. See if they play.
tuhsheen
Post Tue Jul 21, 2020 11:50 am
atc98092 wrote:What is most likely happening is that USB and DLNA support differs on the TV. That actually happens quite often, in that something will work from a USB drive but not via DLNA. Sometimes it's the codec, sometimes the container, and sometimes it's the captions. My Sharp TV uses the Roku OS, so not a direct comparison.
I was thinking of trying to get a roku, but I live in Belgium so that's out of the question. I'm also not certain it would even fix the issue.
The TV runs its own OS.. Its very basic with very limited functionality.
tuhsheen
Post Tue Jul 21, 2020 11:51 am
Yeah tried the embedded subs, sadly doesn't work.
I'll give WMS a go, thanks.
Post Tue Jul 21, 2020 1:28 pm
Windows media streaming services are extremely limited. It does a bit of transcoding, but you have zero control over what it does and doesn't do. I tried it (admittedly many years ago) and it was generally worthless for most of my library. Once I found Serviio I've never used it again, and in fact have it disabled on both of my media serving computers.
freaknik
Post Mon Jul 27, 2020 10:51 pm
Try converting them to ASS maybe that will play? I have chromecast and using generic profile and they work srt ass or embedded. Idk what srtwiz is but I assume that checks formatting?
Crundi
Post Mon Oct 05, 2020 10:54 am
And what is the best way to convert to .ASS? Do I need Aegisub for this? I prefer to use only certified software. And not only that. To take the same jewelry and gemstones, there is a whole gemstone certification responsible for the quality and generally takes into account most of the features. So does the software.
grosjean
Post Mon Feb 07, 2022 9:24 am
Dear all,
someone as any news for how to get subtitling working on sharp TV ?
as I tested so far, I can only use "burn into video" which cause than not all text lines from srt file are displayed
thanks
Post Mon Feb 07, 2022 3:00 pm
grosjean wrote:Dear all,
thanks
The display of captions is solely up to the player, so the TV determines what captions are displayed. And for TVs, they generally only display text based captions. If your media consists of ripped DVDs and Blu Rays, they use captions that are image based, not text. And your TV will never display them.
However, SRT files are text based, so in theory I would expect them to work. But not knowing what model Sharp TV you have, I have no idea what caption support it has.
grosjean
Post Tue Feb 08, 2022 9:18 am
Dear Dan,
I have a Sharp Aquos TV, but despite as I selected Sharp Aquos in the menu, to get it working I must untick Transcoding in delivery menu, otherwise, i get a black screen with obviously a message error but I don't have the time to see it, it just blink.
If I tick to burn subtitle in the image, It can works with some video, doing that, I suppose it finally transcode anyway
So I suppose not all Aquos TV are working the same way.
I also try to put the transcoding buffer in a ramdisk instead of /tmp on hardisk, supposing that may accelerate transcoding process, but no change doing that.
Maybe I can ask to Sharp but I dont know where?
Thanks and regards,
Raphaël
Post Tue Feb 08, 2022 2:31 pm
Aquos is a name they apply to numerous different models. If you can find the model number, I might be able to find a manual online that lists the supported file formats.
grosjean
Post Tue Feb 08, 2022 5:17 pm
It's Sharp 32BC5E.
Yes if you find some information, that's interrest me.
Raphaël
Post Tue Feb 08, 2022 11:55 pm
Found a manual online, but it was of no help. It does not list any of the supported media types. The only spec I could find is that the TV support H.264 and H.265, the latter being a bit of a surprise for a TV that isn't 4K. But I can find nothing online that lists the media and codecs supported. That list generally includes the types of captions supported. They simply don't make that info available.
Users browsing this forum: No registered users and 49 guests
