How to fix bad match for Game of Thrones
trafo
Post Mon Jul 20, 2020 2:18 am
So I have a folder with Game of Thrones as such:
However, Serviio recognizes it as...a cartoon parody?
If anyone could advise on how to fix this, it would be appreciated.
Post Mon Jul 20, 2020 2:28 pm
Re: How to fix bad match for Game of Thrones
Easiest way would be to add the IMDB reference for the series into the path. For example if all of your files are currently stored in a folder called “C:\Game of Thrones\” then rename the folder to “C:\Game of Thrones [tt0944947]\”.
Adding the IMDB reference forces Serviio to use that when searching for the series name, removing any ambiguity.
trafo
Post Mon Jul 20, 2020 2:33 pm
DenyAll wrote:Easiest way would be to add the IMDB reference for the series into the path.
Never knew that. Very useful tip, thanks!
