Help file mkv Samsung PS50C6500
tkos
Post Wed Feb 02, 2011 7:38 pm
Re: Help file mkv Samsung PS50C6500
Here is an FFMpeg output file for a file that does work fine in 0.4.2 and doesn't in 0.5. The log comes from FFMpeg using 0.4.2 which is currently installed.
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i c:\bones.mkv
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
built on May 3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
erver --enable-memalign-hack --enable-libmp3lame --enable-w32threads --extra-ldf
lags=-L/static/lib --extra-cflags=-I/static/include
libavutil 50.15. 0 / 50.15. 0
libavcodec 52.66. 0 / 52.66. 0
libavformat 52.62. 0 / 52.62. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
[matroska @ 0131bab0]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (48000/2002)
Input #0, matroska, from 'c:\bones.mkv':
Duration: 00:43:01.02, start: 0.000000, bitrate: 448 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1280x720, PAR 1:1 DAR 16:9, 23.98 tb
r, 1k tbn, 47.95 tbc
Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Post Wed Feb 02, 2011 7:43 pm
That looks normal.... I'd need detail logs from both versions when trying to play the same file...
tkos
Post Wed Feb 02, 2011 8:13 pm
I followed the instructions for turning on detailed logging, but all my log file is doing is going through my MP3 files and checking them, without serviio doing anything. I played the MKV file but it didn't show up in the log, though it did play just fine.
Post Mon Apr 18, 2011 2:42 pm
bitbucket ticket 281 - Vorbis Audio Support - marked as resolved (0.6)
https://bitbucket.org/xnejp03/serviio/i ... io-support
Previous
