Which ports to open in firewall?
efef
Post Tue Sep 01, 2020 9:31 pm
The server app contains port 23424 and 23524 , not specifying protocol.
Also: in the mean time, I connected the Android client to local IP, it does show how many arttsts there are , and the albums, and the cover, number of items inside...but when entering everything is "No content"
However: the Android client does not fail to already annoy me with ads, is that gone when paying for "pro" version of the server?
Post Wed Sep 02, 2020 12:20 am
Re: Which ports to open in firewall?
Ports 23424/23524 are for MediaBrowser, not the console. For external access outside your firewall, you only need these opened. I don't bother with SSL, so I have 23424 as the only open port in my router. I have both TCP/UDP enabled, although I don't know if both are necessary. Unless you have a static public IP address, don't forget you'll need some sort of dynamic DNS service to get you a consistent URL.
If by Android client you mean ServiiGo, you'd be best asking in the forum that is specific to that app. The Serviio developer is not the person who has created or maintains that app. See this location in the forum for help with ServiiGo: viewtopic.php?f=17&t=6803
The Pro version of Serviio is required for ServiiGo (and MediaBrowser) to work, but it has nothing to do with any ads in the app. As I said, they are completely different products.
cmakula
Post Tue Sep 08, 2020 10:04 pm
Dan is correct.
Technically you only need port 23424/TCP for http or 23524/TCP for https. I do not have UDP open...
:ugeek:
Serviio Server - Dell PowerEdge R420, Dual Xeon E5-2420, 4x120 GB SSD RAID 0, 64 GB RAM (Serviio running from RAMdisk), 4 NICs (aggregated to LAN), 10Gbe to NAS, Ubuntu Server 24.04.3
NFS File Server - Synology DS1517+, 20TB disk space (5x4TB), 4 NICs (aggregated to LAN), 10Gbe to Serviio Server
Users browsing this forum: Google [Bot] and 156 guests
