Shortcut/customize playlist
Snorkum
Post Sun Aug 02, 2020 1:26 pm
Shortcut support
or playlist which I can specify in folder I like to have it displayed.
Thank you
Werner
Post Sun Aug 02, 2020 7:09 pm
Re: Shortcut/customize playlist
Playlists are not visible in any folder. They only appear in the Playlists presentation. I don't think I'd want them appearing within my regular media folders.
Paul C
Post Fri Sep 04, 2020 10:42 pm
Snorkum wrote:... I like to have it displayed.
Werner
Under the existing Serviio playlist arrangements if you select a playlist the contents are displayed (providing console/Presentation/audio/playlist etc. is set to "Display category").
You can then decide to play it or not.
This is it as it appears in Serviio MediaBrowser but it is the same in any control app such as BubbleUPnP (either as a list or thumbnail grid whichever you choose).
The playlists are in the folder you specify in the Library as above.
I keep them in folder D:\media-library\audio\playlists
and do not mix them up with the music folders which are in D:\media-library\audio\music
Post Fri Sep 04, 2020 11:16 pm
Paul, he wanted the playlist to appear under the Folders view. It has nothing to do with the presentation settings.
Paul C
Post Sat Sep 05, 2020 9:26 am
Snorkum wrote:.... playlist which I can specify in folder I like to have it displayed. Werner
Dan, I see where you are coming from. I read it as a folder not folder view.
Whichever way then for your music you look in "Folders" (if you use folders - I do not) and for playlists look in "Playlist" which has the code to display the different file types (.m3u, .pls etc).
Werner gets what he wants with an extra click.
Post Sat Sep 05, 2020 8:29 pm
Folder view will not show playlists, regardless of their location. Since my playlist folder doesn't contain anything but playlists, the folder itself isn't even visible in Folder view. Playlists only appear in the Playlist presentation.
Return to Feature requests
Users browsing this forum: No registered users and 206 guests
