So... is this sub dead? I'd buy the pro version if it would
FabrinRodriguez
Post Fri Oct 30, 2020 7:17 am
I'm a total newb at Linux but I'm finding my way round slowly. Trying to get Serviio to run on Linux is just too much like hard work. I feel like I need to spend days/weeks just trying to omegle xender make it work. I've Googled till I'm blue in the face and I've got it running, but it's not right.
Ironically Serviio is the only thing keeping me running Windows at the moment
Last edited by FabrinRodriguez on Sat Oct 31, 2020 7:04 am, edited 1 time in total.
Post Fri Oct 30, 2020 3:58 pm
Re: So... is this sub dead? I'd buy the pro version if it wo
You posted this in a location that wouldn't likely get any response, so it was moved here.
You haven't said what the issue is, what you've done, or what distro you're using. Need some additional detail to provide some assistance. I'm not a Linux expert by any stretch, but I have installed Serviio on a Linux box on the past just to play with it. Yes, it's different than a Windows install, but then almost anything Linux related requires more expertise compared to Windows.
cmakula
Post Fri Oct 30, 2020 7:10 pm
Being a network guy, I use Linux pretty much constantly...
What issues are you facing? Hopefully I can help as well.
:ugeek:
Serviio Server - Dell PowerEdge R420, Dual Xeon E5-2420, 4x120 GB SSD RAID 0, 64 GB RAM (Serviio running from RAMdisk), 4 NICs (aggregated to LAN), 10Gbe to NAS, Ubuntu Server 24.04.3
NFS File Server - Synology DS1517+, 20TB disk space (5x4TB), 4 NICs (aggregated to LAN), 10Gbe to Serviio Server
Users browsing this forum: Baidu [Spider], Google [Bot] and 11 guests
