Sony BDP-S3500
BillReed
Post Wed Nov 11, 2020 2:55 pm
Sony BDP-S3500
What profile should I use with the BDP-S3500?
Thanks!
Bill
Post Wed Nov 11, 2020 10:12 pm
Re: Sony BDP-S3500
I have an S3500, and have used the "Sony BDP-Sx100 (2013) profile" without a problem. The biggest problem is that Sony has dropped support for DTS Master Audio over DLNA (older players it worked fine), so you have to select a different audio track if that is the default. That profile is pretty old, so it you have any 4K media it might not transcode them to a supported format.
That said, we've pretty much stopped using that player, instead using an Nvidia Shield with Kodi as the player. That way I get all the audio codecs without a problem.
BillReed
Post Sun Nov 15, 2020 6:33 pm
Re: Sony BDP-S3500
Thanks Dan !!
