MKV Fast Forward working!!
erilod
Post Wed Dec 18, 2013 12:51 pm
Re: MKV Fast Forward working!!
zip wrote:
BlackThorne wrote:just to add some info-
I've tried everything in this and other threads. non worked for some MKV i've checked.
strangely enough after installing Samsung's AllShare- it worked there.
so this is really an issue of the software rather than firmware.
[i'm using 46 C650 TV]
any idea what could possibly be the reason...?
MOst likely because serviio now transcodes MKVs with level > 4.2 and with mkv header stripping. You could remove he matchers from your profile. This should be rectified in 1.1 as well.
I just reinstalled my headless Linux (Debian) server and now I can't RW/FF or time skip in my MKVs which I could earlier from my Samsung TV with these exact mkv-files. Could this be related to "header stripping" och MKV transcoding? Is MKV transcoded by default? I'm running default settings on my Serviio 1.3.1 installation. Is 1.1 referring to Servio version 1.1? In that case I guess this is not why I'm having issues.
In my installaion I built ffmpeg from source according to this guide: https://trac.ffmpeg.org/wiki/UbuntuCompilationGuide. Is there something missing in that build that is required?
Best regards, Erik
Jyrx
Post Wed Apr 30, 2014 2:58 pm
MKV Fast Forward works fine on Samsung 2014 H-models, out from the box :D .
Tested on UE40H6200, UE55HU7500
matiello
Post Fri May 16, 2014 2:52 am
I don't know what I have to do.
I've tried many solution in the forum like the command in "--clusters-in-meta-seek", using old versions.
But my FW/RR can't work.
I have a HT-F4500 and using the last Serviio version and Samsung TV / player E/F Series.
Someone have any idea that I can try?
Regards
Beeboop
Post Sun Feb 01, 2015 4:01 pm
Jyrx wrote:MKV Fast Forward works fine on Samsung 2014 H-models, out from the box :D .
Partially true. It works for most movies. It does not work for Prometheus and I have no idea why. I'm trying to fix it now.
naderb
Post Mon Jan 02, 2017 11:01 am
Issue resolved !!
Hey Just fix the file with converting it!! it should take much time !!
######## Linux Command #######
ffmpeg -i from.mkv -codec copy tofile.mp4
Also you can run a cron job to conver all files from MKV to MP4 and delete the old MKV !!
The new file should be working with all forwarding options and everything.
Regards,
Nader Barakat
Croobum
Post Tue Jul 16, 2019 7:39 am
Thanks for advice,i wil try it,
mikestanley464
Post Mon Nov 16, 2020 5:29 pm
The .MKV needs to be muxed with the option --clusters-in-meta-seek in mkvmerge. This was turned on by default in previous versions, but is off by default now. This is required to be able to jump backwards and forwards on Samsung players.
ka81
Post Mon Nov 16, 2020 6:01 pm
Where exactly is that setting ?
pan Oleksiy
Previous
