Assign server to a subnet
tcamuso
Post Thu Nov 19, 2020 5:44 pm
I have more than one subnet connected to my W10-pro workstation.
How can I tell which subnet serviio is connected to?
Can I assign serviio to a specific subnet?
Post Thu Nov 19, 2020 6:30 pm
Re: Assign server to a subnet
I assume you mean you have two separate network cards in your computer. Serviio by default will auto-select a card, and I believe it's based on which one loads first. But you can manually assign which network card Serviio uses using the Serviio console, at the bottom of the status page. Just click the Bound IP address box and select the desired NIC. You can also look at the Serviio log to see what IP address it has bound to.
tcamuso
Post Thu Nov 19, 2020 7:43 pm
atc98092 wrote:I assume you mean you have two separate network cards in your computer. Serviio by default will auto-select a card, and I believe it's based on which one loads first. But you can manually assign which network card Serviio uses using the Serviio console, at the bottom of the status page. Just click the Bound IP address box and select the desired NIC. You can also look at the Serviio log to see what IP address it has bound to.
Many thanks! Yes, two network cards, each connected to a different subnet.
I see now where I can bind to a given subnet at the bottom of the status page.
But where is the serviio log?
Post Thu Nov 19, 2020 8:08 pm
On a Windows PC, the log is in the C:\Program Files\Serviio\log folder. It maxes the file at 5 MB, then starts a new log. The most current log has the .log suffix, while the next oldest will be .1, .2, etc.
tcamuso
Post Thu Nov 19, 2020 8:52 pm
Again, many thanks, Dan!
Users browsing this forum: Baidu [Spider] and 55 guests
