Yet Another SeasonVar Plugin [seasonvar.ru]
aiscy
Post Thu Dec 21, 2017 1:37 pm
Re: Yet Another SeasonVar Plugin [seasonvar.ru]
victor500k wrote:Большое спасибо, всё работает!
Спасибо что отписались:)
AQUSTIQ
Post Fri Apr 27, 2018 6:15 pm
Thank you for plugin.
It works fine but anybody know why after 1 week instead of 12 web resources/folders I can see only 2?
aiscy
Post Fri May 04, 2018 10:49 am
AQUSTIQ wrote:Thank you for plugin.
Hi! It only affects the resources that plugin provides?
AQUSTIQ
Post Fri May 04, 2018 9:03 pm
Hi, aiscy!
So far I have used just web resources for this plugin and actually after some time the number of folders been increased to 9 of 12 now. I don't understand what procedure is used to publish those resources over dlna.
For all other static content (movies, music) is not affecting.
I verified missing folders and their url's are still active on seasonvar.ru.
aiscy
Post Sat May 12, 2018 9:31 am
Hi, aiscy!
Sorry for my late reply. Can you show me the log and some urls? I'll try to reproduce the problem.
AQUSTIQ
Post Thu May 17, 2018 8:54 pm
Some examples of errors:
2018-05-16 22:04:56,973 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-10419-Gotem-0001-sezon.html?next=true, will try again soon: Unexpected error while invoking plugin (YetAnotherSeasonVar v4): No match found
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (YetAnotherSeasonVar v4): No match found
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:79)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:187)
   at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:207)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:194)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:100)
   at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.IllegalStateException: No match found
   at java.util.regex.Matcher.group(Matcher.java:536)
   at java_util_regex_MatchResult$group.call(Unknown Source)
   at Parser.secure(YetAnotherSeasonVar.groovy:206)
   at Parser$secure.call(Unknown Source)
   at YetAnotherSeasonVar.extractSeasonInfo(YetAnotherSeasonVar.groovy:70)
   at YetAnotherSeasonVar.extractSeasonInfo(YetAnotherSeasonVar.groovy)
   at YetAnotherSeasonVar.this$4$extractSeasonInfo(YetAnotherSeasonVar.groovy)
   at sun.reflect.GeneratedMethodAccessor1517.invoke(Unknown Source)
   at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90)
   at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233)
   at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:361)
   at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:877)
   at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.callCurrent(PogoMetaClassSite.java:66)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:145)
   at YetAnotherSeasonVar$_extractItems_closure3.doCall(YetAnotherSeasonVar.groovy:117)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
   at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:272)
   at groovy.lang.Closure.call(Closure.java:412)
   at groovy.lang.Closure.call(Closure.java:425)
   at org.codehaus.groovy.runtime.DefaultGroovyMethods.collect(DefaultGroovyMethods.java:2135)
   at org.codehaus.groovy.runtime.DefaultGroovyMethods.collect(DefaultGroovyMethods.java:2105)
   at org.codehaus.groovy.runtime.dgm$82.invoke(Unknown Source)
   at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
   at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
   at YetAnotherSeasonVar.extractItems(YetAnotherSeasonVar.groovy:116)
   at org.serviio.library.online.WebResourceUrlExtractor.extractItems(WebResourceUrlExtractor.java:72)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:34)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:31)
   at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
   at java.util.concurrent.FutureTask.run(FutureTask.java:266)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
   ... 1 more
2018-05-16 22:05:57,466 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-2219-He_vse_starki_umrut--01-sezon.html?next=true, waiting for expiry time to try again: Unexpected error while invoking plugin (YetAnotherSeasonVar v4): http://seasonvar.ru/serial-2219-He_vse_starki_umrut--01-sezon.html
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (YetAnotherSeasonVar v4): http://seasonvar.ru/serial-2219-He_vse_starki_umrut--01-sezon.html
Caused by: java.io.FileNotFoundException: http://seasonvar.ru/serial-2219-He_vse_starki_umrut--01-sezon.html
   at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
   at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
   at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1944)
   at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1939)
   at sun.net.www.protocol.http.HttpURLConnection.getChainedException(HttpURLConnection.java:1938)
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1508)
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492)
   at groovy.lang.MetaClassImpl$GetBeanMethodMetaProperty.getProperty(MetaClassImpl.java:3465)
   at org.codehaus.groovy.runtime.callsite.GetEffectivePojoPropertySite.getProperty(GetEffectivePojoPropertySite.java:61)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callGetProperty(AbstractCallSite.java:227)
   at HTTP$Response.decodeInputStream(YetAnotherSeasonVar.groovy:372)
   at org.codehaus.groovy.runtime.callsite.StaticMetaMethodSite$StaticMetaMethodSiteNoUnwrapNoCoerce.invoke(StaticMetaMethodSite.java:148)
   at org.codehaus.groovy.runtime.callsite.StaticMetaMethodSite.callStatic(StaticMetaMethodSite.java:99)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callStatic(AbstractCallSite.java:165)
   at HTTP$Response.<init>(YetAnotherSeasonVar.groovy:358)
   at org.codehaus.groovy.reflection.CachedConstructor.invoke(CachedConstructor.java:77)
   at org.codehaus.groovy.runtime.callsite.ConstructorSite$ConstructorSiteNoUnwrapNoCoerce.callConstructor(ConstructorSite.java:102)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callConstructor(AbstractCallSite.java:194)
   at HTTP.GET(YetAnotherSeasonVar.groovy:289)
   at HTTP$GET.call(Unknown Source)
   at YetAnotherSeasonVar.extractItems(YetAnotherSeasonVar.groovy:111)
   ... 1 more
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1890)
   at sun.net.www.protocol.http.HttpURLConnection.getHeaderField(HttpURLConnection.java:3000)
   at java.net.URLConnection.getContentEncoding(URLConnection.java:523)
   at java_net_URLConnection$getContentEncoding.call(Unknown Source)
   at HTTP$Response.decodeInputStream(YetAnotherSeasonVar.groovy:369)
   ... 27 more
2018-05-16 22:05:58,417 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-10419-Gotem-0001-sezon.html?next=true, waiting for expiry time to try again: Unexpected error while invoking plugin (YetAnotherSeasonVar v4): No match found
   ... 1 more
AQUSTIQ
Post Thu May 17, 2018 8:57 pm
Just tried to open URL with errors and seems like access is filtered by country. :(
aiscy
Post Fri May 18, 2018 8:50 am
AQUSTIQ wrote:Just tried to open URL with errors and seems like access is filtered by country. :(
I'll see what I can do about it.
aiscy
Post Wed Jun 13, 2018 1:52 pm
Can you try a new version of the plugin?
ivanoff999
Post Tue Jun 26, 2018 1:38 pm
Добрый день,
Перестал работать плагин последней версии, лог прилагаю. Спасибо за Ваш труд
(499.16 KiB) Downloaded 1490 times
Sony Bravia 2010 - KDL-32EX40B Serviio 1.9.2 Pro on Windows 7 x64 SP1/macOS Sierra 10.12.6/Ubuntu Mate 17.04 x64
aiscy
Post Tue Jun 26, 2018 7:19 pm
ivanoff999 wrote:Добрый день,
Здравствуйте. Рад бы помочь, но единственное упоминание моего плагина в логе есть лишь на 51 строке, и то там говорится лишь об его подключении к Serviio.
[maxim@o_o Downloads]$ grep -in 'seasonvar' 'serviio (2).log'
51:2018-06-26 08:50:07,884 INFO  [PluginCompilerThread] Added Web Resouce plugin YetAnotherSeasonVarPlugin v6 (YetAnotherSeasonVar.groovy), version: 6
Шестая версия не работала сразу, или сломалась спустя какое-то время?
ivanoff999
Post Tue Jun 26, 2018 7:28 pm
Так вышло, что перестало работать на предыдущей версии, а 6-ю я установил в надежде, что всё заработает. Видимо, что-то изменили на seasonvar.ru.
А логи я ещё подкину. В медиабраузере Serviio видны названия и иконки сериалов, но нет содержимого, на телевизоре видны только названия, без отображения иконок. Естественно, что пути прописаны правильные, я перепроверил, т.к. на seasonvar.ru их иногда меняют.
Вообщем странное впечатление.
Дополнение от 24,07,18 - свежий лог, спасибо
(109.45 KiB) Downloaded 1434 times
AQUSTIQ
Post Mon Jul 09, 2018 6:53 pm
Now is not working at all. It seems like the path to video is encrypted.
2018-07-27 10:30:22,841 WARN  [FeedUpdaterWorker] Failed to retrieve online item information for #2aHR0cDovL2RhdGExMS1jZG4uZGF0YWxvY2sucnUvZmkybG0v//b2xvbG8=NTNmNGU2YWUzYTZiMDM4ODNlZGU5MmYzZjUwZjc2YmIvN2ZfVGhlLkV4cGFuc2UuUzAxRTAxLjcyMHAuV0VCLnJ1cy5Mb3N0RmlsbS5UVi5hMS4yOS4xMS4xNS5tcDQ=. It might not play.
        at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:321)
        at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveTechnicalMetadata(FeedUpdaterWorker.java:246)
        at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:120)
        at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:481)
        at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:100)
        at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:138)
        at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:300)
        ... 3 more
2018-07-27 10:30:23,037 WARN  [FeedUpdaterWorker] Failed to retrieve online item information for #2aHR0cDovL2RhdGEwNy1jZG4uZ//b2xvbG8=GF0YWxvY2sucnUvZmkybG0vNTNmNGU2YWUzYTZiMDM4ODNlZGU5MmYzZjUwZjc2YmIvN2ZfVGhlLkV4cGFuc2UuUzAxRTAyLjcyMHAuV0VCLnJ1cy5Mb3N0RmlsbS5UVi5hMS4xOC4xMi4xNS5tcDQ=. It might not play.
        ... 3 more
AQUSTIQ
Post Fri Jul 27, 2018 2:35 pm
aiscy, Just FYI plugin still not work.
If you need some help to work on the plugin send me a message.
YurArm
Post Wed Oct 17, 2018 6:40 pm
У всех не работает же плагин? все молчат просто...
Автор не отвечает четыре месяца.
Чем все пользуетесь, чтобы сеазон-вар смотреть?
ни 5ая ни 6ая версия не работают. в логе упоминания плагина нет, только как и у других зашифрованные url'ы типа #2aHR0cDovL2RhdGExMC1jZG4uZGF0YWxvY2sucnUvZmkybG0vZTM2MDZlNWQ2Y2E3YWIyZjRmOTliZjQ5Nzk5ZTU2NmYvN2ZfU3Rhci5XYXJzLlJlYmVscy5TMDRFMTAuNzIwcC5XRUIucnVzLkxvc3RGaWxtLlR//b2xvbG8=WLmExLjIzLjAyLjE4Lm1wNA==. It might not play.
Или может знаете нормальный аналогичный dlna-сервер со встроенной поддержкой всяких серверов типа сизонвар
Liiion911
Post Sun Dec 27, 2020 7:19 pm
Попробуйте вот эту версию, я не силен в java но поправил (проверить не могу, проги нету этой).
Если что, пишите в telegram: @liiion911
(18.19 KiB) Downloaded 1084 times
Previous
Return to Available plugins
