Serviio for Synology DS220+ package
derhorst89
Post Tue Dec 15, 2020 6:12 am
Hey folks,
i'm owner of a brand new Synology DS220+ cause i read that for Synology does exists Serviio one of the main reasons for the buy.
But if i insert the repository, i'm only finding one package "OpenRemote" no other package. Does someone have the package who can give me for a manual installation?
Or other tips?
Thanks in advance.
chartrider
Post Sat Dec 26, 2020 3:04 pm
Re: Serviio for Synology DS220+ package
Same here. Got a DS920+ but unfortunately the Package Center only shows a package named "Open Remote". I would be really happy, if someone can give me the package for manual installation. I also buyed a Pro-License, which is useless without the software.
Thanks in advance.
farly
Post Fri Jan 01, 2021 12:43 pm
use serviio docker version, you will have latest version 2.1 and everything works fine: https://hub.docker.com/r/riftbit/serviio/
Acetone
Post Fri Jan 01, 2021 2:27 pm
I just can't get my head round docker, I can get the image, then get the container running, but then what, how do I get serviio running so I can set the folders to monitor.
farly
Post Fri Jan 01, 2021 2:53 pm
did you read docker forum ? viewtopic.php?f=14&t=25052
i think there are reaply for all questions.
Acetone
Post Fri Jan 01, 2021 6:45 pm
Sorted (I think) thanks
Users browsing this forum: Bing [Bot] and 39 guests
