Search with wildcard or partial string??
kittmaster
Post Thu Mar 11, 2021 2:52 pm
I was looking for Shawshank redemption on my NAS.
I know I have it.
Typed "Shaw" ..... everything but came back.
Typed "*Shaw"....nothing found.
Typed "*Shaw*"....nothing found.
Typed "Shawshank"....only result found.
Does the search engine not support partial or wildcard searches?
Shouldn't it?
Am I missing something?
Thx.
Post Thu Mar 11, 2021 5:38 pm
Re: Search with wildcard or partial string??
Is this using MediaBrowser?
Not certain why Shawshank isn't returning results. I tried searching for Star and it returned all my Star Wars and Star Trek movies and TV shows. It also returned Belle Starr and some titles with Stars in the name. But I could not get * to work as a wild card. But it appears that it uses some sort of wild card in its default search function. When I entered flight I had titles with Flight and also Flint. So no idea what sort of algorithm is in use.
kittmaster
Post Thu Mar 11, 2021 7:01 pm
Yes, in mediabrowser.
I just did it again with "the shaw" nothing returns...I get shawn mendes, fast/furious hobbs and shaw.....but no shawshank.
if I type the work shawshank, I get it as a single return.
This is very silly......and ineffective.
Any other thoughts?
Do you have that movie to search for to see if your results match mine?
Post Thu Mar 11, 2021 8:40 pm
No, I don't. So I did the next best: I copied another video and renamed it with that movie title. Serviio added it no problem, so I went to search. Yep, no results searching for shaw, redemp, redempt. I typed shawshank and it did return. Sounds like Zip needs to add/fix wildcard searching.
kittmaster
Post Thu Mar 11, 2021 9:29 pm
So how do we get that info to him?
Post Thu Mar 11, 2021 10:28 pm
You can send him a PM, or submit a trouble ticket in Bitbucket. I usually do both with a bug or request. https://bitbucket.org/xnejp03/serviio/issues
kittmaster
Post Sat Mar 13, 2021 11:48 pm
I will do both...thanks for the confirmation......that is very strange behavior.
Users browsing this forum: Baidu [Spider] and 73 guests
