Serviio Backdoor or Calling Home?
mrmichaelrb
Post Tue May 25, 2021 9:57 am
There are two unexplained lines in my netstat:
# netstat -n -p
Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        1      0 192.168.0.200:34222     52.202.215.126:443      CLOSE_WAIT  1169/java
tcp       25      0 192.168.0.200:38588     172.67.138.108:443      CLOSE_WAIT  1169/java
I've verified that process id 1169 (java) is my Serviio process. Why is Serviio contacting these addresses?
I've disabled external things like OpenSubtitles.org and Trakt.tv, so I don't understand why Serviio would be calling out to anywhere...
52.202.215.126 is associated with:
canyouseeme.org
checkip.org
172.67.138.108 is associated with:
yougetsignal.com
framearthouston.com
1477floribundaave.com
Post Tue May 25, 2021 4:47 pm
Re: Serviio Backdoor or Calling Home?
I could see CheckIP for MediaBrowser determining it's public IP address. But Zip is the only person that can really answer that question.
Post Fri Jun 04, 2021 3:07 pm
yep, these services check open ports and your public IP address. These are used for the data on Remote tab in the console and for the Alexa skill (for example). I think ServiiGo might also use these.
It's literally juast calling these APIs every few minutes to keep the data up-to-date.
