server doesn't appear on Samsung TV UE46C8700
guimarc
Post Thu Apr 21, 2011 4:58 pm
I've a problem with servio 0.5.2. The server is not recognized by my TV, while there was no problem with 0.4.2 version. How can I do?
Thank you for your help
Post Thu Apr 21, 2011 5:26 pm
Re: server doesn't appear on Samsung TV UE46C8700
can you post your log from the Serviio log directory? so we can see what Serviio is doing?
guimarc
Post Tue Apr 26, 2011 9:55 pm
hi,
Sorry for the late answer to your reply. Where can I find the log? I'm not too familiar with this kind of things!
Post Wed Apr 27, 2011 12:06 am
guimarc wrote:hi,
Please provide a DETAILED log ( link in my signiture for how to )
Elohim
Post Wed Apr 27, 2011 1:29 pm
I have the same problem with a samsung UE32c5100
Serviio worked perfectly before the 1st reboot and then is no more detected on the TV
here the log
2011-04-27 15:21:16,703 INFO  [MediaServer] ------------------------------------------------------------------------
2011-04-27 15:21:16,703 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-04-27 15:21:16,703 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-04-27 15:21:16,703 INFO  [MediaServer] http://www.serviio.org
2011-04-27 15:21:16,703 INFO  [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2011-04-27 15:21:16,703 INFO  [MediaServer] OS Windows XP x86 5.1
2011-04-27 15:21:16,703 INFO  [MediaServer] File encoding: windows-1252
2011-04-27 15:21:16,890 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-04-27 15:21:16,984 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-04-27 15:21:16,984 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2011-04-27 15:21:18,890 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-04-27 15:21:18,937 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-04-27 15:21:19,406 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-04-27 15:21:19,406 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-04-27 15:21:19,671 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-04-27 15:21:19,671 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-04-27 15:21:19,812 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-04-27 15:21:19,828 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-04-27 15:21:19,921 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-04-27 15:21:19,937 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-04-27 15:21:20,093 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-04-27 15:21:20,093 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-04-27 15:21:20,187 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-04-27 15:21:20,203 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-04-27 15:21:20,453 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-04-27 15:21:20,468 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-04-27 15:21:20,531 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-04-27 15:21:20,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-04-27 15:21:20,859 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-04-27 15:21:20,859 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-04-27 15:21:21,468 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-04-27 15:21:21,468 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-04-27 15:21:21,625 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-04-27 15:21:21,625 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-04-27 15:21:21,718 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-04-27 15:21:21,734 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2011-04-27 15:21:21,734 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2011-04-27 15:21:21,796 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-04-27 15:21:21,796 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-04-27 15:21:21,812 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-04-27 15:21:21,859 INFO  [WebServer] WebServer starting on port 8895
2011-04-27 15:21:21,875 INFO  [Device] Created UPnP Device with UUID: c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629, bound address: 192.168.0.10
2011-04-27 15:21:21,921 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-04-27 15:21:21,937 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-04-27 15:21:21,937 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-04-27 15:21:21,937 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-04-27 15:21:21,937 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-04-27 15:21:21,937 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-04-27 15:21:21,937 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1303910481937, LastAccessTime = 1303910481937, getTimeToLiveSeconds() = -1, createTime = 1303910481937 ]
2011-04-27 15:21:21,937 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-04-27 15:21:21,984 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-04-27 15:21:21,984 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-04-27 15:21:21,984 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-04-27 15:21:21,984 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-04-27 15:21:21,984 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-04-27 15:21:21,984 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-04-27 15:21:21,984 INFO  [CompositeCacheConfigurator] Finished configuration in 47 ms.
2011-04-27 15:21:21,984 DEBUG [DiscoveryManager] UPNP device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 (192.168.0.10) is available
2011-04-27 15:21:21,984 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-04-27 15:21:21,984 INFO  [EventDispatcher] Starting EventDispatcher
2011-04-27 15:21:21,984 INFO  [RendererSearchSender] Searching for Renderer devices
2011-04-27 15:21:21,984 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-04-27 15:21:21,984 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-04-27 15:21:22,000 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Miniport d'ordonnancement de paquets) and address 192.168.0.10, timeout = 0
2011-04-27 15:21:22,187 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-04-27 15:21:22,203 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-04-27 15:21:32,203 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-04-27 15:21:42,234 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:27
2011-04-27 15:21:45,171 INFO  [UpdateChecker] Checking if a new version is available
2011-04-27 15:21:46,000 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-04-27 15:21:46,562 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2011-04-27 15:21:48,671 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2011-04-27 15:21:48,703 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2011-04-27 15:21:50,781 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-04-27 15:21:50,796 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = null
2011-04-27 15:21:50,812 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:50,828 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:50,828 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,843 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,843 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,859 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,859 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:50,875 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-04-27 15:21:50,875 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:50,890 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,890 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,906 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:50,906 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,921 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,937 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2011-04-27 15:21:50,937 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2011-04-27 15:21:50,953 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-04-27 15:21:50,953 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,968 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-04-27 15:21:50,984 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,000 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-04-27 15:21:51,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,031 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,031 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,046 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,046 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,062 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-04-27 15:21:51,062 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,093 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,093 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,109 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,109 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,125 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-04-27 15:21:51,125 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,140 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,140 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,156 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,171 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,171 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,187 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,187 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,203 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2011-04-27 15:21:51,203 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2011-04-27 15:21:51,218 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2011-04-27 15:21:51,218 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,234 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-04-27 15:21:51,234 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2011-04-27 15:21:51,250 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2011-04-27 15:21:51,265 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,265 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,281 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,281 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,296 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,296 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,312 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,328 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,328 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,343 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,359 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,359 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,375 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,390 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,390 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,406 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,406 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,421 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-04-27 15:21:53,171 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-04-27 15:22:05,125 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2011-04-27 15:23:09,453 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:12
2011-04-27 15:23:14,015 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2011-04-27 15:24:22,406 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:03
2011-04-27 15:25:25,937 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:20
2011-04-27 15:26:46,218 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:06
2011-04-27 15:27:52,890 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:15
Any Advice ?
Post Wed Apr 27, 2011 1:39 pm
Do you fix (recommended) the IP address of your Samsung device?
Elohim
Post Wed Apr 27, 2011 1:47 pm
I don't know how to fix it.... with the router ?
I'm not very good with network things
PaDeng
Post Thu Apr 28, 2011 1:28 pm
another hi... I have the same problem with a Samsung UA32C5000QR
the TV and the laptop do not see one another as far as I can tell. I am not the brightest bulb on computer things but I do think I was able to turn on the detailed log.
(67.58 KiB) Downloaded 1123 times
Any assistance is appreciated.
serviio log.txt
(67.82 KiB) Downloaded 1061 times
Post Thu Apr 28, 2011 1:42 pm
Post Thu Apr 28, 2011 4:49 pm
This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
PaDeng
Post Thu Apr 28, 2011 10:02 pm
Cerberus wrote:This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console.
"machine running Serviio" does this refer to the TV or the computer?
Post Thu Apr 28, 2011 11:53 pm
The computer m8 :)
PaDeng
Post Fri Apr 29, 2011 10:29 pm
Serviio still doesn't work for me. But thanks for the human response. :?
Post Fri Apr 29, 2011 10:41 pm
PaDeng wrote:Serviio still doesn't work for me. But thanks for the human response. :?
Please post your serviio log file.
PaDeng
Post Sat Apr 30, 2011 3:51 am
2011-04-30 04:35:06,888 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-04-30 04:35:55,416 INFO [Messages] Loaded console message bundle for locale: en
2011-04-30 04:37:26,707 INFO [Messages] Loaded console message bundle for locale: en
INFO [MediaServer]
2011-04-30 04:34:49,201 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2011-04-30 04:34:49,201 INFO [MediaServer] OS Windows XP x86 5.1
2011-04-30 04:34:49,201 INFO [MediaServer] File encoding: windows-1252
2011-04-30 04:34:49,201 INFO [MediaServer] ------------------------------------------------------------------------
2011-04-30 04:35:00,951 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-04-30 04:35:03,747 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-04-30 04:36:26,680 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-04-30 04:36:29,195 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-04-30 04:36:29,867 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-04-30 04:36:30,445 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-04-30 04:36:30,539 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-04-30 04:36:30,648 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-04-30 04:36:30,711 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-04-30 04:36:30,914 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-04-30 04:36:30,961 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-04-30 04:36:31,242 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-04-30 04:36:31,726 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-04-30 04:36:31,867 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-04-30 04:36:31,976 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-04-30 04:36:56,490 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-04-30 04:36:57,287 INFO [WebServer] Socket buffer set to 65535 bytes
2011-04-30 04:36:59,506 INFO [WebServer] WebServer starting on port 8895
2011-04-30 04:37:00,568 INFO [Device] Created UPnP Device with UUID: 204683ed-9f48-3c47-b70d-0da4ab7276fa, bound address: 192.168.1.4
2011-04-30 04:37:05,958 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-04-30 04:37:06,849 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-04-30 04:37:07,146 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-04-30 04:37:07,146 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-04-30 04:37:07,146 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-04-30 04:37:07,146 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-04-30 04:37:07,146 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1304113027146, LastAccessTime = 1304113027146, getTimeToLiveSeconds() = -1, createTime = 1304113027146 ]
2011-04-30 04:37:07,193 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-04-30 04:37:08,489 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-04-30 04:37:08,489 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-04-30 04:37:08,489 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-04-30 04:37:08,489 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-04-30 04:37:08,489 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-04-30 04:37:08,489 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-04-30 04:37:08,489 INFO [CompositeCacheConfigurator] Finished configuration in 1500 ms.
2011-04-30 04:37:08,505 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-04-30 04:37:08,505 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-04-30 04:37:08,505 INFO [EventDispatcher] Starting EventDispatcher
2011-04-30 04:37:09,505 INFO [RendererSearchSender] Searching for Renderer devices
2011-04-30 04:37:09,505 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-04-30 04:37:26,848 INFO [UpdateChecker] Checking if a new version is available
2011-04-30 04:37:45,612 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-04-30 04:37:47,034 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-04-30 04:38:20,313 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-04-30 04:38:22,094 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-04-30 04:39:45,682 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 04:44:56,491 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 04:50:06,268 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 04:55:16,001 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 05:00:25,750 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 05:05:35,516 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 05:10:45,439 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 05:15:55,302 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 05:21:05,572 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 05:25:42,873 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-04-30 05:25:42,873 INFO [EventDispatcher] Leaving EventDispatcher
2011-04-30 05:25:42,873 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-04-30 05:25:42,889 INFO [WebServer] WebServer shutting down
2011-04-30 05:25:42,905 INFO [Device] Updated bound IP address of Device with UUID: 204683ed-9f48-3c47-b70d-0da4ab7276fa, bound address: 192.168.1.3
2011-04-30 05:25:42,905 INFO [RendererSearchSender] Searching for Renderer devices
2011-04-30 05:25:42,905 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-04-30 05:25:42,905 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-04-30 05:25:42,920 INFO [WebServer] WebServer starting on port 8895
2011-04-30 05:25:42,920 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Intel(R) PRO/Wireless 3945ABG Network Connection - Packet Scheduler Miniport) and address 192.168.1.3, timeout = 0
2011-04-30 05:25:42,920 INFO [EventDispatcher] Starting EventDispatcher
2011-04-30 05:25:44,358 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-04-30 05:25:46,139 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-04-30 05:25:46,139 INFO [EventDispatcher] Leaving EventDispatcher
2011-04-30 05:25:46,139 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-04-30 05:25:46,139 INFO [WebServer] WebServer shutting down
2011-04-30 05:25:46,155 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-04-30 05:25:48,076 INFO [WebServer] WebServer starting on port 8895
2011-04-30 05:25:48,076 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-04-30 05:25:48,076 INFO [EventDispatcher] Starting EventDispatcher
2011-04-30 05:25:48,076 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-04-30 05:25:48,076 INFO [RendererSearchSender] Searching for Renderer devices
2011-04-30 05:25:48,076 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Intel(R) PRO/Wireless 3945ABG Network Connection - Packet Scheduler Miniport) and address 192.168.1.3, timeout = 0
2011-04-30 05:26:00,998 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-04-30 05:26:01,201 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-04-30 05:26:01,201 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-04-30 05:26:10,435 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 05:31:20,581 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 05:33:19,265 INFO [WebServer] WebServer shutting down
2011-04-30 05:33:19,265 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-04-30 05:33:19,265 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-04-30 05:33:19,265 INFO [EventDispatcher] Leaving EventDispatcher
2011-04-30 05:33:19,281 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-04-30 05:33:44,624 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-04-30 05:33:45,733 INFO [DatabaseManager] Shutting down database
2011-04-30 05:33:50,343 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-04-30 05:37:59,546 INFO [MediaServer] ------------------------------------------------------------------------
2011-04-30 05:37:59,546 INFO [ServiioConsole] Starting Serviio Console
2011-04-30 05:38:00,156 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-04-30 05:38:00,156 INFO [MediaServer] Petr Nejedly 2009-2011
2011-04-30 05:38:00,156 INFO [MediaServer] http://www.serviio.org
2011-04-30 05:38:00,156 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2011-04-30 05:38:00,156 INFO [MediaServer] OS Windows XP x86 5.1
2011-04-30 05:38:00,156 INFO [MediaServer] File encoding: windows-1252
2011-04-30 05:38:00,156 INFO [MediaServer] ------------------------------------------------------------------------
2011-04-30 05:38:16,468 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-04-30 05:38:18,937 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-04-30 05:38:20,578 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-04-30 05:39:07,156 INFO [Messages] Loaded console message bundle for locale: en
2011-04-30 05:39:29,484 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-04-30 05:39:30,250 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-04-30 05:39:30,687 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-04-30 05:39:30,984 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-04-30 05:39:31,062 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-04-30 05:39:31,171 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-04-30 05:39:31,234 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-04-30 05:39:31,500 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-04-30 05:39:31,546 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-04-30 05:39:31,812 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-04-30 05:39:32,250 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-04-30 05:39:32,359 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-04-30 05:39:32,453 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-04-30 05:39:42,343 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-04-30 05:39:42,703 INFO [WebServer] Socket buffer set to 65535 bytes
2011-04-30 05:39:43,671 INFO [WebServer] WebServer starting on port 8895
2011-04-30 05:39:44,140 INFO [Device] Created UPnP Device with UUID: 92364609-eb74-3e48-a97f-fb1c988d0a03, bound address: 192.168.1.3
2011-04-30 05:39:45,109 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-04-30 05:39:45,250 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-04-30 05:39:45,343 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-04-30 05:39:45,343 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-04-30 05:39:45,343 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-04-30 05:39:45,343 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-04-30 05:39:45,343 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1304116785343, LastAccessTime = 1304116785343, getTimeToLiveSeconds() = -1, createTime = 1304116785343 ]
2011-04-30 05:39:45,343 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-04-30 05:39:45,734 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-04-30 05:39:45,734 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-04-30 05:39:45,734 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-04-30 05:39:45,734 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-04-30 05:39:45,734 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-04-30 05:39:45,734 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-04-30 05:39:45,734 INFO [CompositeCacheConfigurator] Finished configuration in 453 ms.
2011-04-30 05:39:45,734 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-04-30 05:39:45,734 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-04-30 05:39:45,734 INFO [EventDispatcher] Starting EventDispatcher
2011-04-30 05:39:45,890 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Intel(R) PRO/Wireless 3945ABG Network Connection - Packet Scheduler Miniport) and address 192.168.1.3, timeout = 0
2011-04-30 05:39:45,921 INFO [RendererSearchSender] Searching for Renderer devices
2011-04-30 05:39:45,921 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-04-30 05:39:56,125 INFO [Messages] Loaded console message bundle for locale: en
2011-04-30 05:39:56,250 INFO [UpdateChecker] Checking if a new version is available
2011-04-30 05:40:13,312 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-04-30 05:40:14,781 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-04-30 05:40:47,796 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-04-30 05:40:50,328 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-04-30 05:42:20,250 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 05:47:32,093 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 05:52:42,453 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 05:57:52,421 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 06:03:02,359 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 06:08:12,296 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 06:13:22,218 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 06:18:32,140 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 06:23:42,062 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 06:28:52,000 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 06:34:01,968 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 06:39:11,921 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 06:44:21,906 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 06:49:31,875 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 06:54:41,828 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 06:59:51,859 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 07:05:01,812 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 07:10:11,796 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 07:15:21,906 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 07:20:31,937 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 07:25:41,859 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 07:30:51,937 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 07:36:01,906 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 07:41:11,843 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 07:46:21,984 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 07:51:31,921 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 07:56:41,921 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 08:01:53,281 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 08:07:03,234 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 08:12:13,218 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 08:17:23,343 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 08:22:33,343 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 08:27:43,343 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 08:32:53,515 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 08:38:03,484 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 08:43:13,453 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 08:48:23,453 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 08:53:33,437 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 08:58:43,375 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 09:03:53,328 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 09:09:03,328 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 09:14:13,281 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 09:19:23,265 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 09:24:33,250 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 09:29:43,218 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 09:34:53,156 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 09:40:03,109 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 09:45:13,093 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 09:50:23,078 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 09:55:33,046 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 10:00:42,984 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 10:05:52,921 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 10:11:02,890 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 10:16:12,828 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 10:21:22,781 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 10:26:32,781 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 10:31:42,796 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 10:36:38,796 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-04-30 10:36:38,796 INFO [EventDispatcher] Leaving EventDispatcher
2011-04-30 10:36:38,812 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-04-30 10:36:38,812 INFO [WebServer] WebServer shutting down
2011-04-30 10:36:38,812 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-04-30 10:36:40,921 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-04-30 10:36:52,781 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 10:39:30,250 INFO [WebServer] WebServer starting on port 8895
2011-04-30 10:39:30,250 INFO [RendererSearchSender] Searching for Renderer devices
2011-04-30 10:39:30,250 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-04-30 10:39:30,250 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-04-30 10:39:30,250 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Intel(R) PRO/Wireless 3945ABG Network Connection - Packet Scheduler Miniport) and address 192.168.1.3, timeout = 0
2011-04-30 10:39:30,250 INFO [EventDispatcher] Starting EventDispatcher
2011-04-30 10:42:03,125 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
2011-04-30 10:47:13,250 WARN [LibraryManager] Cannot read metadata of file C:\Documents and Settings\Owner.YOUR-6BE6174B3F\My Documents\My Pictures\1-25-2011\DSC01318.JPG via extractor EMBEDDED. Message: Invalid Segment: insufficient data
Post Sat Apr 30, 2011 8:35 am
Re: server doesn't appear on Samsung TV UE46C8700
so 192.168.1.4 is the ip of the PC running serviio ??
PaDeng
Post Sat Apr 30, 2011 11:41 am
I've entered 192.168.1.3 now as the bound ip address, this is the pc. 192.168.1.4 is the tv. (as far as I --computer fairly challenged--- have been able to determine--are the ip addresses for those items.
Post Sat Apr 30, 2011 12:37 pm
oh yes my mistake i see it changes lower down the log, have you restarted serviio since you set that IP ? and can you now see serviio from the tv?
PaDeng
Post Sat Apr 30, 2011 1:30 pm
I have restarted it, and refreshed everything also. I think the only thing I have not done is to re-boot the computer. The TV and computer/serviio still do not see one another.
I am sure I have done something stupid in the setup, but currently and obviously have no idea what it may be.
Post Sat Apr 30, 2011 1:47 pm
PaDeng wrote:I have restarted it, and refreshed everything also. I think the only thing I have not done is to re-boot the computer. The TV and computer/serviio still do not see one another.
is the TV deffinately connected to the network and can you access the net from it ?
Users browsing this forum: Baidu [Spider], Google [Bot] and 5 guests
