Files with Dolby Vision not displayed
Post Sun Aug 15, 2021 3:21 am
I downloaded a test video that uses HEVC video with Dolby Vision. Serviio recognizes the file as a new addition, but is not visible in MediaBrowser or my DV enabled players. The log has this entry:
WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (F:\Test Videos\dolby-vision-nasa.mp4). Message: Unknown video codec.
Besides not recognizing the H.265 video, which I believe it should, it's also talking about processing metadata, even though I have metadata retrieval disabled for that library folder. Everything in that folder is a test clip that doesn't have any online metadata available.
Why isn't Serviio recognizing this file?
Why is it looking for metadata when that function is disabled for that location?
Post Tue Aug 17, 2021 3:22 pm
Re: Files with Dolby Vision not displayed
I think someone suggested to replace ffmpeg with the latest version.
Post Tue Aug 17, 2021 6:00 pm
I'll try that. I had a C drive failure last week and had to rebuild my media server. So Serviio is a completely default installation.
Post Wed Aug 18, 2021 12:52 am
Yep, that did it. I guess using a version from May 2020 was a bit out of date. :D
Users browsing this forum: Google [Bot] and 151 guests
