Image Index not working
grazer75
Post Mon Sep 20, 2021 4:06 pm
I had a problem of recognize a new folder, so i deleted the share and started from the beginning.
During this after 4 hours i turned my computer off and restarted on next day.
Now it seems that it only index 2 folders and ignores the other, doesn`t matter if i delete the share and recreate it.
Also the ignore feature for cr2 or raw is not working either, like it ignores it now.
Any conclusion how to solve it?
I don`t want to loose my video shares as i have a link in oculus quest with pegasus player
Can i delete a file, reg key to solve the problem?
Windows 10 + Servio Pro 2.1 is beeing used
Post Mon Sep 20, 2021 6:40 pm
Re: Image Index not working
Serviio makes no registry entries, other than what Windows creates to control the service and track install/uninstall procedures. No operational information is located there.
I've recently made some changes on one of my servers and didn't have any issues adding a new shared folder. You are hitting the Save button at the bottom of the page after you create the new shared folder, right? Can you list the steps you took to create the new shared library location?
grazer75
Post Mon Sep 20, 2021 7:44 pm
atc98092 wrote:Serviio makes no registry entries, other than what Windows creates to control the service and track install/uninstall procedures. No operational information is located there.
I delete the share and create a new one, as mentioned before i had to shutdown my computer as i went to sleep.
It seems like it stopped at this point and every time i recreate the share it stops always after the two folders.
I tried with and without poller mechanism also i user ignore files with extension -> cr2,raw
It seems to ignore this setting at all, it scans all files of the two folders including cr2 files.
So it looks like a corruption in C:\Program Files\Serviio\library or? I think while it was writing the index the computer shutdown and corrupted it maybe?
Still don`t understand while ignore file type does not work anymore too with pictures.
Example from log:
2021-09-20 21:36:01,340 INFO [MediaFileIndexer] Added file 'J:\_arbeit\shooting\AO\_MG_5256.JPG' (title: _MG_5256) to Library
2021-09-20 21:36:03,244 INFO [MediaFileIndexer] Added file 'J:\_arbeit\shooting\AO\_MG_5257.CR2' (title: _MG_5257) to Library
ignore files with extensions it is enough to write: cr2,raw or do i have to use eg: cr2, jpg (I think it worked before with cr2, raw)
Post Mon Sep 20, 2021 11:42 pm
Yeah, it might be a DB corruption. Unfortunately, the only fix for that is to remove Serviio and do a clean install. I don't use the exclude function, so can't speak to that issue. I had to rebuild my primary media computer a couple of weeks ago due to a failed SSD OS drive, so fortunately all my media (on different hard drives) was intact and once I installed Serviio it didn't take long to get back up and running. Depending on the complexity of your configuration, it shouldn't take too long to do a reinstall. I know you mentioned a couple of video shares you don't want to lose, but I don't know what's involved with setting those up.
grazer75
Post Tue Sep 21, 2021 6:44 am
The scan problem was a conflict with qsync as it seems, i have to stop qsync first.
In the old version this was working.
Guess qsync locks folders.
But ignore cr2 if i only write this in the field does not work.
But is this really a db corruption if the scan does not ignore cr2 files as set?
Db corruption in my opinion is not the problem.
Post Tue Sep 21, 2021 6:51 pm
Yeah, I was only considered a DB issue with the adding shared folder issue. I can't help with the ignore files issue, unfortunately.
Users browsing this forum: Baidu [Spider] and 49 guests
