Movie Cover Names for better description
morci
Post Sat Apr 24, 2010 11:41 pm
Excellent product, great work!
Is it possible for Serviio to recognise the movie covers other than Movie.jpg and Cover.jpg ? I have tried the following combinations and they dont work:
Unforgiven_cover.jpg -> doesnt work
Unforgiven_movie.jpg -> doesnt work
movie_Unforgiven.jpg -> doesnt work
cover_Unforgiven.jpg -> doesnt work
movie.jpg = works
cover.jpg = works
Is it possible for the serviio to recognise the word 'cover' or 'movie' in the name so that the filename can be more descriptive? File name organisation could be much better and easier than having so many files called 'movie' or 'cover' and not knowing what movie it belongs to?
Even better just name the 'JPG' the same as the movie?
so My movie folder example would be:
folder name is 'Unforgiven'
movie avi is 'Unforgiven.avi' therefore
movie cover is 'movie-Unforgiven.jpg' or 'cover-Unforgiven.jpg' or just SIMPLY 'Unforgiven.jpg' - Is this possible ?
Thank you for your time
Morci
Morci
Serviio User :)
Samsung LA40B750U1F LCD | Windows XP Sp3 unpatched |System: MSI 865Neo2 -Platinum - P4 3.4Ghz - 3GB RAM
How To: Get Non Working AVI Files Playing http://forum.serviio.org/viewtopic.php?f=10&t=4780
How To: Fix FFW + REW in AVI's - when containing OpenDML format http://forum.serviio.org/viewtopic.php?f=5&t=323
Post Sat Apr 24, 2010 11:50 pm
Re: Movie Cover Names for better description
http://www.serviio.org/index.php?option ... icle&id=12
It says: dvdcover.jpg, movie.jpg, name including "poster".jpg, {media_file_name}.jpg
I haven't tried it recently but it use to work ;-)
morci
Post Wed Apr 28, 2010 1:56 am
Yes you are right - my mistake. I tried the same picture name as the movie name and it works.
A quick question?
Is it possible to change the folder icons shown in the TV? In my SAMSUNG TV it shows just the folder in 'Blue' Colour - I would like to change it to a more pleasing folder icon that shows that its a movie folder, the same would apply to all other folder icons, like music, etc - Is this possible or its restricted by SAMSUNG?
Thank you and keep up the great work
Manuel
Morci
Serviio User :)
Post Wed Apr 28, 2010 9:09 am
No, it's not possible unless you hack the TV ;-)
Return to Feature requests
