Search location
doogydawg
Post Sun Nov 28, 2021 6:44 pm
Search location
I have upgraded my Mac operating system to Monterey.
When I load Servvio and go to users to look for a file as usual I normally pick my desktop and then the folder where the movie is.
When I now try to select the location the desktop no longer shows up.
Just the following
Screenshot 2021-11-28 at 18.35.17.png (195.34 KiB) Viewed 5376 times
Post Sun Nov 28, 2021 11:57 pm
Re: Search location
Sounds like something you need to ask in a Mac support forum. Serviio is only going to see the file structure of your hard drive(s). It sounds like Apple moved the location of the Desktop folder. I have zero experience with Mac, so can't offer any other suggestions.
doogydawg
Post Tue Nov 30, 2021 9:58 pm
Re: Search location
atc98092 wrote:Sounds like something you need to ask in a Mac support forum. Serviio is only going to see the file structure of your hard drive(s). It sounds like Apple moved the location of the Desktop folder. I have zero experience with Mac, so can't offer any other suggestions.
Thanks for taking the time to reply.
I think you might be right.
I have moved all my movie folders into the main Movies folder.
Not a problem really, just used to having it all on the desktop.
Users browsing this forum: Baidu [Spider] and 108 guests
