no subtitles
mikkidk
Post Thu Apr 21, 2011 12:03 am
no subtitles
After reinstalling serviio I can't get subtitles (SRT) on film. Whats wrong?
Post Thu Apr 21, 2011 8:27 am
Re: no subtitles
you probably don't have the proper profile selected
mikkidk
Post Fri Apr 22, 2011 11:46 pm
Re: no subtitles
profile on servio or on the panasonic tv?
And how do I make the correct profile?
mikkidk
Post Fri Apr 22, 2011 11:50 pm
Re: no subtitles
I have chosed panasonic viera as my profile. This worked fine until I reinstalled serviio.
Post Sat Apr 23, 2011 10:42 am
Re: no subtitles
mikkidk wrote:I have chosed panasonic viera as my profile. This worked fine until I reinstalled serviio.
In the serviio console find you tv listed and select panasonic viera TV profile then subtitles will work. :)
mikkidk
Post Mon Apr 25, 2011 9:20 pm
Re: no subtitles
Ok. Now It works fine. Thanks for your help :)
Post Tue Apr 26, 2011 2:55 am
Re: no subtitles
mikkidk wrote:Ok. Now It works fine. Thanks for your help :)
your welcome but thing to remember is IF your tv changes its IP then you may have to select the profile again for it to work. :)
Return to Panasonic
